It is currently Mon Jul 28, 2025 2:34 pm
PostPosted: Mon May 05, 2014 11:14 pm
I am debating in my head what to do for a dash, I am torn between a full walnut dash something like this http://minispares.com//product/classic/DASH005.aspx or a cooper style center one like this http://minispares.com/product/classic/13H4444KIT.aspx what is everyone thoughts? I do currently have a 3 gauge set to suit the walnut type and a few 2 gauge as well, but I would need the full set to go the cooper one. I like the look of of both, I just can't decide which look i prefer?
So what do you prefer and why?
PostPosted: Mon May 05, 2014 11:25 pm
not a fan of the walnut just cos so many people have it & rovers were similar, ive been thinking about getting a dash from a mob in the uk that can do any design you like http://www.dashofcolour.co.uk/
i really like this 1 in particular Image
PostPosted: Mon May 05, 2014 11:28 pm
Yes I saw their site, I agree I really liked that one too! bit more $ for that one though wonder what their postage here is like.
PostPosted: Tue May 06, 2014 8:28 am
have you had a look at ebay uk?
http://www.ebay.co.uk/itm/MINI-DASH-DAS ... 20e3fc3771
I saw these matching units some time ago.
It's easy once you know how.
PostPosted: Tue May 06, 2014 9:29 am
Yeah I saw them, don't mind bit pricey for postage.
PostPosted: Tue May 06, 2014 9:41 am
whats the postage like from mini spare's for the dash? minisport sell the minispares dash's but i think there a bit more than buying direct around $500 from minisport aus
PostPosted: Tue May 06, 2014 10:24 am
I'm a big fan of the works style dashes, you can make one up of a centre binnacle and works pods from minispares.
Though it's definitely a matter of taste!
I wasn't happy with any of the options so my auto electrician is making up a custom carbon job. Bearing in mine that my car has no air vents, radio or speakers or any creature comforts at all though. Mine's basically all gauges and kill switches.
PostPosted: Tue May 06, 2014 10:34 am
I like these innocenti style ones from abs motorsports http://www.absmotorsport.co.uk/index.ph ... 2gtiF5yGhM
They have some great dash styles that you don't see everyday.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Tue May 06, 2014 10:51 am
For the walnut dash was about $65 AUS with a few other things added. Which I didn't think was to bad for the size of it I had bit of a search around last night and most of the othe UK site were around or above $100AUS for postage for their dashes.
PostPosted: Tue May 06, 2014 11:12 am
That's pretty good. Makes it just under $300 to your door. A lot cheaper than ms
PostPosted: Tue May 06, 2014 11:31 am
I DIY'd mine - found some scrap plywood and got a nice piece of burled blackwood from my dad (who was a sawmiller). I think it cost me $8 all up, because I bought the finish.
PostPosted: Tue May 06, 2014 12:34 pm
A fundamental question is whether you plan on using top and bottom crash pads. Rover dashes, which are the typical after market ones only fit if you have a top crash pad. The older style timber ones fit inside the steel top and bottom rails.
M
PostPosted: Tue May 06, 2014 12:42 pm
Looks good Irish I had thought about this, do you have to allow for the curve when using the crash pads?
I do have the crash pads and again I'm flexible on using them depending on the direction I take, I was thinking of using them though.
PostPosted: Tue May 06, 2014 12:54 pm
It was a while ago I made it, but I used a template I found on www.theminiforum.co.uk for the general outline, and it worked OK. There's not much curve there so it would only add a few mm to the length. I did find that mine curved vertically a little bit though which left a bit of a gap (which you can see in the picture), but nothing terrible.
PostPosted: Tue May 06, 2014 5:11 pm
i made mine out of MDF and then covered it in vinyl, i just shaped the mdf so suit the curve on the dash rails i can take pics of it if you want. there so easy to make, and you can put radio/ gauges anywhere you want, i also modify the plastic gauge cluster on the clubman to suit the dash. so it looks factory.
Users browsing this forum: No registered users and 121 guests
