It is currently Mon Jul 28, 2025 3:46 am
 Post subject: Right hand fuel tank
PostPosted: Fri Apr 25, 2014 12:37 pm
Hi guys, first time post.
I have a right hand fuel tank that I would like to install into my Deluxe project. What do I need to do to mount the tank in position? Can I make a paper template from the left side to get the position for the right side hole? This is about the last hurdle I have before I can put some paint on. Any guidance would be very appreciated.
Chris
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
 Post subject: Re: Right hand fuel tank
PostPosted: Fri Apr 25, 2014 1:05 pm
That's how I did it when I fitted one to my wasaMatic.
You can buy a RH tank mounting kit but I just shaped a bit of wood for underneath, and used a standard tank strap.
No the hole for the tank is not a mirror image of the left. Sitnlo posted the correct measurements, do a search.
PostPosted: Fri Apr 25, 2014 1:10 pm
here you are;
viewtopic.php?f=2&t=84662&p=932763#p932763
PostPosted: Fri Apr 25, 2014 1:30 pm
Just found the measurements. Will go and cut a hole and see what happens!
Thanks for all the help and info.
5/72 Clubman Gt
PostPosted: Wed May 07, 2014 5:48 pm
How did this work out for you? I was going to make it easy on myself and just make a reverse template of the left side. Please tell if there is any reason why this method will not work.
PostPosted: Wed May 07, 2014 5:50 pm
PostPosted: Wed May 07, 2014 6:22 pm
timmy201 wrote:
TK wrote:
Wonder if the plastic tanks made by Paul Gulson are any different, his instructions are to make a template from the LHS tank.
PostPosted: Wed May 07, 2014 7:38 pm
I used those measurements and it looks pretty much right. I cut the hole a little bit smaller so I can adjust to suit. I had bought a gulson plastic tank previously but it didnt come with any instructions. I sat that in but didnt like the look of it so its back on the shelf for the moment. Might go back to repairing the metal one.
5/72 Clubman Gt
PostPosted: Thu May 08, 2014 9:03 am
you can do it but your tank wont fit through the hole. That's why there is something wrong with this method.
1962 Mini Speed sports sedan
PostPosted: Sat May 10, 2014 10:00 am
The metal bracket on the LH floor, is it required on the right hand side? I have a rusty leyland parts shell that I can cut it from. Also on the back of the seat panel there is a bracket welded on there and a captive nut setup. Should I weld these bits on?
5/72 Clubman Gt
PostPosted: Sat May 10, 2014 10:19 am
There is a RH bracket you can buy, but I used a block of wood.
To attach the RH strap I just drilled thru the seat back and used a nut & bolt.
PostPosted: Sat May 10, 2014 7:14 pm
Spent a few hours tinkering in the boot area today. I managed to get the right hand tank hole correctly located and the tank is mounted. Looks good. Even the plastic tank I have looks fine now so might I run that.
5/72 Clubman Gt
Users browsing this forum: Majestic-12 [Bot] and 77 guests
