It is currently Mon Jul 28, 2025 9:58 am
PostPosted: Thu May 08, 2014 6:44 pm
Why not use clubman one, shouldn't be hard to find.
PostPosted: Thu May 08, 2014 6:56 pm
I do like the look of it. Low profile and all. It sits right up and out of the way.
PostPosted: Thu May 08, 2014 6:58 pm
It looks well made, I bet it works better than a Clubman one too.
I kept the std MiniMatic freshair heater, stuck a 3" Attwood bilge blower in the air duct behind the heater, then put a VH44 booster under the dash. I can pull the motor out without disturbing the booster or its plumbing.
Plenty of legroom still and the brakes work great!
PostPosted: Fri May 09, 2014 12:08 pm
TweedGrey wrote:
It does indeed look like a tidy unit and it would be easy to install under the dash per the video on the mini-mania site.
Oooh I like that idea of putting the booster under the dash and leaving the heater in situ. I'd not even thought of that option! I'm guessing you have it tucked up nice and high... Do you have it on the passenger or driver side Doc? You wouldn't happen to have a wee piccy at all?
Sorry I can't get these links to show here as pics, since flickr `improved' their website. :x
https://www.flickr.com/photos/31275265@N05/9266582210/
https://www.flickr.com/photos/31275265@N05/9266581508/
https://www.flickr.com/photos/31275265@N05/9263804543/
PostPosted: Fri May 09, 2014 12:16 pm
Undoubtedly because you can't sell advertisements on the flikr website if the customers aren't seeing the advertisments..
PostPosted: Fri May 09, 2014 12:22 pm
There must be a way, I will get my #1 son the Master Programmer/Hacker to have a look. 8)
PostPosted: Fri May 09, 2014 12:36 pm
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri May 09, 2014 1:06 pm
There are 2 std Mini front brake hoses from the booster up to the bulkhead plate.
I had to put a 7/8" holesaw thru the bulkhead to allow 2 pipes and the vac hose.
The hard lines are 750mm and 950mm? I think, I got the local brake shop to make them and I bent them to fit in.
Bilge blower I used is here, it is all plastic but has handled the heat for the last 10 years.
It's a bit noisy but you really only need it in traffic when stopped.
http://www.biasboating.com.au/High_Capa ... p/4646.htm
PostPosted: Fri May 09, 2014 2:26 pm
Note the nose of the booster points uphill a little for easier bleeding.
[edit] bloody typo...
Last edited by drmini in aust on Fri May 09, 2014 4:33 pm, edited 1 time in total.
PostPosted: Fri May 09, 2014 4:47 pm
I see KT26 runners! Haven't seen them in years!
PostPosted: Fri May 09, 2014 5:12 pm
Ah yes they were a legendary improvement from the old issue of dunlop volleys :shock:
PostPosted: Fri May 09, 2014 5:47 pm
TweedGrey wrote:
You know (this will sound crazy) I think they even made steel toe KT26's there for a while!
PostPosted: Fri May 09, 2014 6:08 pm
Damn Mick you are starting to make me feel old..................
PostPosted: Fri May 09, 2014 6:47 pm
Wait till their considered retro and you'll feel in touch with your youth again.
I've got some original volleys here somewhere. They're still new and date stamped from the 70s 8)
PostPosted: Fri May 09, 2014 8:53 pm
You're not old until you can remember having those Bata Scout school shoes with " THE COMPASS IN THE SOLE" :lol:
Users browsing this forum: jimb and 79 guests
