It is currently Thu Jul 24, 2025 11:13 am
 Post subject: floatlevel
PostPosted: Thu May 29, 2014 8:50 am
Hi, I have a hairbrained idea!
I have this issue with poor acceleration after corners etc.
new coil, leads, plugs and dizzy
my idea is to fit another gasket under the float lid, anyone done this before?
i have no further adjustment with washers.
my plugs are black on the outer and tan colour on the insulator
It's easy once you know how.
 Post subject: Re: floaslevel
PostPosted: Thu May 29, 2014 8:58 am
What's your engine?
 Post subject: Re: floatlevel
PostPosted: Thu May 29, 2014 9:08 am
998, std I think apart from oversized bores.
extractors and sport muffler.
minispares heated manifold, not heated yet.
rebuilt 1 1/2 SU with pancake filter.
pulsar dizzy gt 40 and resistor plugs @ 28 thou gap. inductive core leads. (all new)
PostPosted: Thu May 29, 2014 9:11 am
Is the problem after turning left, turning right, or both?
And what needle is in it?
PostPosted: Thu May 29, 2014 9:12 am
One gasket won't be enough. Sounds like your level is down by about 1/4 inch. A std 998 doesn't drink too much.
PostPosted: Thu May 29, 2014 9:17 am
Needle appeared to be std, am thinking may need to remove and check for straitness.
also is a bit of a slug at low rpm, under 2000
should all the plug be the same colour, my tuning skills only go as far as rotary and reed valve kart engines.
wish I had one of those 50mm tryton slide carbs now.
PostPosted: Thu May 29, 2014 9:18 am
I'd find an early float you can adjust, these new nylon ones are rubbish. An SU deserves better... :x
PostPosted: Thu May 29, 2014 9:36 am
have forgotten to mention when the engine is running poor if I pull the chocke it goes better, sounds like is running lean?
PostPosted: Thu May 29, 2014 9:40 am
Sounds like you have a needle in which is too lean. This means you can set idle mixture OK as they are all much the same at that step. But the needle hasn't enough taper, so when you gun it, it goes lean. Classic result from fitting a Ramflo filter and a standard needle.
Pull the needle out and read the code off the top part, tell us what it is.
PostPosted: Thu May 29, 2014 10:16 am
appears to have a number 1 stamped on it.
is approx 8mm shorter than a std one.
PostPosted: Thu May 29, 2014 10:33 am
new hairbrained idea, have fitted the old damper with std needle?
one is fixed other is spring loaded
PostPosted: Thu May 29, 2014 1:07 pm
Standard needle in a 998 Mini S was an ABX according to my Leyland black book.
Or possibly an ADF (the book is a bit ambiguous here)
Both are leaner down low and richer up high than a #1 is. But if running a Ramflo filter you probably want it richer still.
I would suggest a #7 or a CP4. I have one of each here if you want them..
Put all these numbers into http://www.mintylamb.co.uk/suneedle/ and you can compare them.
PostPosted: Sat May 31, 2014 4:59 pm
I'm having the same leaning out issuse at half throttle. Anytime I come to a hill I have to floor it up it cos at half the car looses so much power it's fine at idle and ok flat out but better with the choke out... Plugs are a nice color... What's everyone's recommendations for a new needle ??
Current needle ADF
Stock 1275 a+ HS4 heated manifold with ramflo..
64' 850 1275cc
PostPosted: Sat May 31, 2014 6:54 pm
have you tried the comparison type chart the Doc mentioned in the previous thread?
should help.
PostPosted: Sat May 31, 2014 7:21 pm
should help.
There are now something like 700?! different SU needles.
The examples I gave are just some that I have. To really know you have the right one requires an air/fuel ratio meter and maybe a dyno- or go for a drive with the A/F meter and put it under full load through the rev range.
Personally, I prefer carbies with jets in `em, not needles... which is why I run a 45 Dellorto. But I'm olde, hence olde skool...8)
