It is currently Sat Jul 19, 2025 12:15 am
 Post subject: Dumb Question of the Day
PostPosted: Thu May 29, 2014 2:39 pm
No nuts, bolts, screws or nails. Can't see any clips, grommets, latches, jubilees or clamps.
I've pulled pretty hard, but maybe I need to pull harder. So how in the hell do I remove the Handbrake Handle from my '98 Rover?
1998 Rover Mk VII
2001 Honda CBR 929RR (street)
2014 BMW S1000RR (track)
PostPosted: Thu May 29, 2014 2:42 pm
It's just pushed on, but because its rubberised its hard to remove.
Ive seen the odd one glued on too - not sure if that was factory or not though.
PostPosted: Thu May 29, 2014 3:06 pm
Try warming it up with a heat gun to make it release a bit.
They are fitted tight.
"Let us remove your "SHORTS"
PostPosted: Thu May 29, 2014 3:13 pm
Thanks guys. I think I'll buy a proper heat gun on the way home. The Missus' hair dryer just isn't cutting it these days.
1998 Rover Mk VII
PostPosted: Thu May 29, 2014 3:20 pm
Try twisting it - that often helps.
PostPosted: Thu May 29, 2014 4:34 pm
You need to stick your tongue out just a little.
A filter strap can help break the seal.
PostPosted: Thu May 29, 2014 4:40 pm
If its rubber, try peeling up a bit and squirting air thru a small nozzle up it !!
Works for motorcycle hand grips
PostPosted: Mon Jun 02, 2014 11:52 am
Yep, mine was glued on. After some prying, heating and clever use of fencing wire I managed to slide it off. I installed my fly-away handbrake and had some fun on a rainy Sunday in an empty carpark. I also found out that my cable needs some adjusting, as the passenger side didn't want to lock quite as nicely as the driver side. Good times.
1998 Rover Mk VII
