It is currently Sat Jul 19, 2025 2:49 pm
PostPosted: Thu May 29, 2014 4:26 pm
I'm looking at fitting a set of 14 x 6 inch wheels with 195/60 R14 tyres to my 78 Clubbie. Will they fit without too much modification? (I have flared arches as I'm currently running 165/60 R12's).
If not possible what are the largest wheels that will fit? Any photo's of examples greatly appreciated 8)
PostPosted: Thu May 29, 2014 4:45 pm
You can fit 15 inch wheels to a Mini. The problems start when you try to fit tyres.
By my estimates your current tyres have a diameter of 19.9" (502mm) and you want to fit a tyre with a dia of 23.21" (589mm)
How much space is there between the front of the rear tyre and the trailing arm? You need 44mm.
PostPosted: Thu May 29, 2014 4:46 pm
13secmini put a set of 14s on his `Daihatsu MiniK'. They fit, but I dunno what the tyre profile or size is.
PostPosted: Thu May 29, 2014 4:57 pm
14" rims with 195/40/14 tyres are comparable to 175/50/13 wheels - problem is the tyres are VERY difficult to obtain. I think only TOYO make them and you'd have to get them from Japan.
PostPosted: Thu May 29, 2014 5:00 pm
Slightly misled you all sorry..... My current tyres are 165/55 R12's therefore the diameter is 480mm. The trailing arm distance is only 38mm! Don't think the 14 inch idea is going to work!
PostPosted: Thu May 29, 2014 5:59 pm
I think you'll foul the front guards with 6" wide tyres when you turn. I'm pretty sure they need to be thinner.
PostPosted: Thu May 29, 2014 6:34 pm
force racing do a 15x5" rim but good luck in finding rubber bands to fit them and start from 1000pounds to buy, there was a guy here in SA who had 14" rims he bought tires from japan IIRC
PostPosted: Thu May 29, 2014 6:57 pm
These are 17x7" on an 850. It does have significant modifications for these to fit. Refer to post MNIWRX in engine conversions. Sorry, not sure how to do a link.
Phil
PostPosted: Thu May 29, 2014 7:07 pm
Cheers Phil I have seen your thread re: MNIWRX and very impressive. I love the Bini rear lights and flat fuel cap but I'm afraid that type of work is way way beyond my abilities! I think the 14 inch wheel idea was just a crazy idea!
PostPosted: Fri May 30, 2014 1:29 am
Harley is 100% spot on. I had them on my 850, same guard mods to the front as you need for 13s and the rears need a trim of the trailing arm bleed nipple dust guard plate thingy!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri May 30, 2014 5:46 am
Phil 850 wrote:
Morris Mini beetle should have put on vw beetle rear lights looks good
PostPosted: Fri May 30, 2014 11:43 am
I have seen 15's on a mini in amagazine somwhere. They required the guard to be cut though - not sure you want to go to that extreme. Did look pretty good though.
PostPosted: Fri May 30, 2014 12:03 pm
viewtopic.php?f=40&t=84259
PostPosted: Sat May 31, 2014 9:14 pm
Rover Cooper
mutant mini used to run 14's but I think he got his from Germany, see if he will pop his head up on this topic.
PostPosted: Sun Jun 01, 2014 7:22 pm
I have also got a clubbie with 175/50/13 . They were rubbing the guards , so I cut the panels for more room . Then stuck the flares on can't tell they have been cut. The 14 inch wheels would look awesome.Here is a couple of photosImageImageImage
Users browsing this forum: No registered users and 72 guests
