It is currently Fri Jul 25, 2025 11:41 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: floatlevel
PostPosted: Sat May 31, 2014 7:39 pm
I've had a quick play around just selecting needles at random to compare to mine and found a few but don't know if they gonna be a lot richer or only a little..
64' 850 1275cc
PostPosted: Sat May 31, 2014 8:22 pm
This is what I've come up with
64' 850 1275cc
PostPosted: Sun Jun 01, 2014 8:34 pm
have the new needle fitted, DZ.
have had to wind the jet down 6 flats and still too lean.
how far can I go?
do i keep screwing until lifting the damper at idle engine speed slightly increases?
It's easy once you know how.
PostPosted: Sun Jun 01, 2014 8:43 pm
6 flats is only 1 turn, it will go a lot further than that. Keep going.
Eventually it will just reach a limit and not go further.
PostPosted: Mon Jun 02, 2014 8:27 am
from flush the jet has now been wound down 15 flats and is better, stll crackles at full throttle
PostPosted: Mon Jun 02, 2014 8:34 am
Fit a richer needle. ie thinner at the pointy end...
PostPosted: Mon Jun 02, 2014 8:44 am
cant help but think the No 6 looks nice on the Minty SU chart.
PostPosted: Mon Jun 02, 2014 8:49 am
No 6 works well in twin HS4s (1275 motor or bigger).
I have none left but will give you a #7, M6 or M7, take your pick.
PostPosted: Wed Jun 04, 2014 6:22 pm
No 7 works so well I dont want to take any chances trying the m6.
very nice for a 998 carby, looking to get 350 km around town from a tank.
weel see
PostPosted: Wed Jun 04, 2014 10:52 pm
Good to hear it's sorted, at last!! :lol:
PostPosted: Fri Jun 06, 2014 12:19 pm
I have tried the M6 and it is too lean.
No 7 back in.
Now to have the timing properly set.
