It is currently Sat Jul 19, 2025 6:14 am
PostPosted: Mon Jun 02, 2014 5:38 pm
Ok guys I have a 850 mini where the wipers park on the drivers side. When I turn the wipers on they go off window screen on both sides, where they park and the other side ?? Would I have the wrong wiper motor in it ?? The wiper motor is out of a clubbie
PostPosted: Mon Jun 02, 2014 6:06 pm
Try pulling the wiper arms off the splines then put a "tab" of tape on each one, then turn them on and let them self park. this should show you where the wiper arms should be put on. So long as the motor self parks properly.
PostPosted: Mon Jun 02, 2014 6:09 pm
Yer when I do that it goes off the other side of the screen even more And yes it self parks :) I was thinking mayb the clubbie wiper motors have more throw on them then a old 850 one
PostPosted: Mon Jun 02, 2014 6:27 pm
I have a two speed, round body, clubby motor on my 62 850 and it works fine.
PostPosted: Mon Jun 02, 2014 6:28 pm
Hmmm now I'm really confused lol
PostPosted: Mon Jun 02, 2014 6:33 pm
Do they just seem to fall off the windscreen? maybe the worm drive or the gearboxes are worn at that spot only...
PostPosted: Mon Jun 02, 2014 6:34 pm
Yer u can move them when they r parked quite a lot
PostPosted: Mon Jun 02, 2014 6:40 pm
Might be time to pull it all out and inspect the parts.
PostPosted: Mon Jun 02, 2014 6:42 pm
Hmm will have a look after work tomorrow c wat I find
PostPosted: Mon Jun 02, 2014 11:22 pm
There are different degree wheels in the wiper motors
take the steel cover off the wiper motor and look at the round plate inside the cog wheel
it will have numbers stamped on it , eg 105 , 110
PostPosted: Tue Jun 03, 2014 7:45 am
The wheel boxes are different, I think the 850 & Deluxe RH park ones have a smaller gear than the LH park Mini K and Clubby ones with the round motor. So the wipers then go too far unless you change the wheel boxes too.
PostPosted: Tue Jun 03, 2014 1:38 pm
You mention the wheel boxes are worn, you could just use the clubman wheel boxes and arms.
