It is currently Wed Aug 13, 2025 12:37 pm
PostPosted: Tue Jun 10, 2014 4:12 pm
High heel ninja
I have a rebuilt 1100 motor, its in a car running and driving, sitting on a good working rod change box, with all accessories and a full extractor/sports exhaust system, what's the market value of it?
Doogie
PostPosted: Wed Jun 11, 2014 10:14 am
I'll give you a carton for it Doogster ;)
seriously, you'd have to expect it to be worth at least $2K - the motor is worth what it cost to rebuild, the 'box and ancillaries are worth 5-600
obviously an engine builder/mini shop would charge more than that, but they'll be providing some form of warranty
but I'm a known tightarse, so am probably lowballing significantly aren't I
PostPosted: Wed Jun 11, 2014 12:48 pm
mini & moke charge $6k+your old engine & box for a rebuild 1100 & gearbox if that helps any.
PostPosted: Wed Jun 11, 2014 5:47 pm
$5-6 thousand dollars to rebuild a motor where parts are available and reasonably inexpensive. Someone is having a laugh.
PostPosted: Wed Jun 11, 2014 6:56 pm
I'd would guess between $2-$3k. As Simon K said, engine builders would offer warranties etc so the cost would be greater. Add a rebuilt gearbox and diff and you would expect the higher costs. Mini & Moke world would have completly rebuilt everything and included some performance mods as they claim the same power as Cooper S I think. Maybe includes the Cooper S tax if thats the case!!!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed Jun 11, 2014 8:20 pm
My guess at the length of string would be $1500.
You didn't make it clear if YOU rebuilt it; or if it was rebuilt. Price goes down if it was your effort! : )
KB
PostPosted: Thu Jun 12, 2014 12:18 pm
There is engine rebuilding and then there is engine rebuilding.
Rebuilt within tolerances utilising refurbished parts inside spec, eg- Ridge remove on bores and new rings
Rebuilt within tolerance using all new parts (where available) eg- bore and hone, fit new pistons from the supplied box
Rebuilt targeting best tolerances eg-Stress plate bore and hone hot using new matched pistons normally from 4 different boxes and targeting clearances, hone angle/grit to suit the application.
So to buy a rebuilt engine you need to know the parts used and the process level of the rebuilder. The less you know of both the less i'd pay.
With the new Australian Consumer Law, I'd buy from a registered business and have them make a life and power statement, get the engine dyno'd and follow their maintenance directions. Your outlay is somewhat protected and represents more value.
1100 engine $200 - $4500
Users browsing this forum: Bill B and 251 guests
