It is currently Sat Jul 19, 2025 5:51 am
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Jun 13, 2014 7:16 pm
I can confirm the YG2S4 for one in June at least.
I wonder what it meant for the factory in particular to change the number for a simple parts change. The body was the same, the model was the same, the exterior shape and trim was the same, just a different parts fit out.
PostPosted: Fri Jun 13, 2014 7:22 pm
I have a couple of references to changing of stampings to "reduce the number of stamping operations".
The digit that was removed was pretty useless when the car was only being sold under one brand anyway. (and they added the digit back for export cars)
PostPosted: Fri Jun 13, 2014 7:33 pm
If you have a look at issue 14 of the mini experience (Craig Watson) there is an article named mystery machines-1969 cooper S. In that article there are a couple of shots of radiator shrouds on genuine cars and they are all YG2S4 and there are also photos of the numbers in the drain channel, approx 500 less.
Sorry, I didn't see Winabbey's post
PostPosted: Fri Jun 13, 2014 7:45 pm
The cost of simple things can't be underestimated in manufacturing. The Navy's new LHDs will have frame zero (the number of feet from the front is how compartments are identified) at the stern because the cost to have frame 0 labeled the bow would have cost in excess of 5 million dollars in drawings conversions :lol:
Five million is also the number I have had related to me for design change to something as simple as a side mirror made at Ford.
PostPosted: Fri Jun 13, 2014 7:53 pm
Imagine the savings when someone is hammering engine numbers.
If he bashed his thumb one in a thousand times and the engine number is 10 digits long and he stamps 100 motors a day...
PostPosted: Fri Jun 13, 2014 8:27 pm
gtogreen1969 wrote:
9er - Hervey Bay is a long way away. Are you just window shopping at the moment or do you need someone to go and have a look for you. First and main issue is the Compliance plate. I would ask for a photo of the plate because the numbers quoted are not correct.
No, I clearly have a lot more to learn.
Something as basic as chassis and engine numbers are going to need to be spot on for me.
I'm happy to deal with appearance issues but the history of the car would be important to me.
PostPosted: Fri Jun 13, 2014 8:48 pm
winabbey wrote:
Watto's article on the 1969 Cooper S in issue 14 of TME has pictures of the radiator cowl stamping for cars 1119 and 1237. Both have YG2S4.
Unfortunately I don't have documentation or photos for the MK II S I purchased new in October 1969. The registration certificate and insurance paper only has the engine number, not the car number or prefix. Photography was time consuming and very expensive back then. :cry:
And you didnt think every say 10th mini would be faked into a cooper s 45 years later
PostPosted: Sat Jun 14, 2014 5:50 pm
gtogreen1969 wrote:
I put the YG2S4 2022 as 8/1970 and it will have a square compliance plate.
I have car number 2014 and its build date is 05/70, which would agree with Winabbey.
Why is the accelerator pedal grey and not black? Gear stick doesn't look right. When did they change from tin to plastic brake master cylinders?
Member VMCI #19
PostPosted: Sat Jun 14, 2014 6:14 pm
Rookiepilot wrote:
I have car number 2014 and its build date is 05/07, which would agree with Winabbey.
I'm confused with the build date 05/07.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Jun 14, 2014 6:18 pm
Must have been stamped on a Friday.
PostPosted: Sun Jun 15, 2014 10:59 am
Could have been.
Scoop, why are you confused with my build date? What are you basing your dates on?
Maybe if we had access to this elusive register we might have a better idea of what was stamped at the factory.
My car is also fitted with an early thin flange Mk2 block, which I have been told on numerous occasions never existed, in that all Mk2 blocks were thick flange.
Member VMCI #19
PostPosted: Sun Jun 15, 2014 11:05 am
Rookiepilot wrote:
Could have been.
Should have said 05/70 instead of 05/07 that was all.
PostPosted: Sun Jun 15, 2014 11:20 am
Dyslexic me.
Thanks Mick
Member VMCI #19
PostPosted: Sun Jun 15, 2014 11:32 am
Q: What does a dyslexic atheist ponder about in the middle of the night?
A: Is there a Dog?
PostPosted: Sun Jun 15, 2014 9:54 pm
Has anyone spoken to Paul Gulson about this car to see if he remembers any of its history?
New to the forum but am learning at a rapid rate with the wealth of info on here!
1969 Mk1 Cooper S - "Madge" (the plastic surgeon is calling....)
1970 Mk2 Cooper S - "Vinnie" (Almost there....almost there...)
