It is currently Sun Aug 24, 2025 6:35 pm
 Post subject: Handbrake adjustment
PostPosted: Mon Jun 16, 2014 8:54 pm
While trying to adjust my handbrake I noticed that the Quadrant would rotate around and hit the subframe before the handbrake came on.
On investigation I found that the handbrake lever in the rear brake shoe was worn to this shape?
I don't think it should have the little centre groove :?
The car is an 850 fitted with 7 1/2" discs but I don't think the rear wheel cylinders have been changed to 5/8". Should I change them.
Also there are no circlips retaining the brake cylinders so I guess I need these too :evil:
Are my above assumptions correct :lol:
Phil
 Post subject: Re: Handbrake adjustment
PostPosted: Mon Jun 16, 2014 9:09 pm
I think you might have to change cylinders to get it 100%.
Why not just buy complete backing plate set up, wouldn't be much more than all the bits you need to fix yours
PostPosted: Tue Jun 17, 2014 10:25 am
never seen them that shape at all! - I've only ever looked at later cars which have boring straight ones with just a hook at the end
if you don't change the rear wheel cylinders to 5/8" bore, the rear brakes lock up before the fronts in an emergency situation.
PostPosted: Wed Jun 18, 2014 10:08 pm
Bought 5/8" slave cylinders and new handbrake levers. The new ones have a much better mechanical advantage but will require more cable travel.
Perhaps I should weld up my old worn ones !
PostPosted: Wed Jun 18, 2014 10:41 pm
That clevis pin hole looks worn as well on the old one
When it comes to brakes your better of with new parts then trying to reco old parts to save $$$
PostPosted: Thu Jun 19, 2014 5:49 pm
I'm not being tight because I have already bought the new ones.
It's just that I will need a lot more brake cable travel with the new ones because of the difference in lever length .
PostPosted: Thu Jun 19, 2014 5:56 pm
why not redrill cable hole closer to pivot, will increase effort required but lessen travel required
PostPosted: Thu Jun 19, 2014 6:30 pm
Have you undone the nuts on the handbrake handle that should give more travel
PostPosted: Thu Jun 19, 2014 8:01 pm
The problem I was originally having was that the quadrant that the handbrake cable runs around was hitting the subframe before the brake came on.
Fixing the wear on the old lever might cure this with the original lever ratio or as Peterb has indicated I could drill a new hole in the new levers.
PostPosted: Thu Jun 19, 2014 8:37 pm
Try it first with the new lever. The factory did lengthen them to improve performance. (on the Morris 1100 they lengthened the handbrake lever as well!)
PostPosted: Sat Jun 21, 2014 12:17 am
The handbrake quadrants are asymmetric.. they can be installed upside down. If this is done, the symptoms are exactly as you describe...
Had issues with the handbrake on one side of my S for years until this was pointed out by an old and bold ex Morris (sic) apprentice...
Cheers, Ian
PostPosted: Sat Jun 21, 2014 7:27 am
Sorry to hijack thread but it's on similar line. The single cable Rover one's, is it an advantage or just cost saver?
Users browsing this forum: Scoop and 108 guests
