It is currently Sat Jun 21, 2025 3:11 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jun 17, 2014 9:32 pm
How would you get the compression so high? You would be using a small bore head or large bore? Guessing you would need a clearance volume of about 25cc.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed Jun 25, 2014 10:48 pm
Try Charlie Saliba in Clayton for engine cleaning, boring and machining.
PostPosted: Mon Jun 30, 2014 4:41 pm
Use to know Peter Orger when he a Ian ran Orgers.
The work done there was top notch at that time. The boring machine for the offset is perfect for the job and runs a very robust clamp down. I'd also ask for a stress plate hone on the sunnen machine.
Cant talk for the operators now as I dont knowem.
