smc..yes yes you are right about gain, I totally agree... it's page 7 point 5 "The highest gain (defined as high deceleration/pedal force in g/lb, or as pedal force/deceleration in lbs/g) configuration did not provide optimum performance in any of the surface x speed combinations."
High Foot pressure to line pressure is not optimum = boosted is better then unboosted. Additionally overboosted braking was also not optimal as per page 13 2nd para, so it continued to say mildly boosted system seemed desirable.
Now for time for data on pedal application time:
Page 6 shows percentage pedal pressure for:
"day dream braking" = standard motivation
"Oh Shite I need to stop" = induced motivation
Given the people were the same and they had the same physical capabilities across both tests the only differential was mind set. Pedal pressure was increased for the same people and pound pedal pressure to deceleration correlated until brake lockup. With boosted to unboosted line pressure being the same yet pedal pressure being the variable it is then clear the mental effort to apply pedal pressure is the determinant of deceleration.
Man..that took longer then single leading shoe brakes (unboosted
On this subject : Vehicle Standards Bulletin 14 (VSB 14) suggests the LS brakes can only be fitted to a Square Front without booster..... is that right?
