It is currently Fri Aug 01, 2025 9:53 pm
 Post subject: Gearbox upgade info
PostPosted: Sun May 18, 2014 12:02 am
Hi guys, I would like to know what is recommended when rebuilding a gearbox to go under 100+hp? The casing is a 22G1228. I will obviously replace bearings etc but what about bulk rings? Is there anything that needs to be uprated for the torque? Standard type diff or X pin? Any advice would be appreciated.
Thanks
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
 Post subject: Re: Gearbox upgade info
PostPosted: Sun May 18, 2014 8:11 am
I've got north of 125HP at the crank, and I'm running stock drop gears, Mk2S gearbox, 3.647 diff, with a comp diff pin and spider gears.
All bearings were replaced, and the baulk rings were back ground .020" for greater life.
It's only a road car; for khanas etc you would want a 4 pin diff at least, or a Quaife.
If buying new baulk rings I would try them on a gear for fit. If they rock about, do not buy them. They will be worn out before bedded in.
New current baulk rings from Minis Plus and Karcraft seem OK in this regard.
PostPosted: Sun May 18, 2014 8:34 am
What part of the baulk ring do you take the .020" off? Do you need to do anything special with the drop gears? You seem to have a lot of handy little mods for making everything better!
5/72 Clubman Gt
PostPosted: Sun May 18, 2014 10:51 am
A standard baulk ring is about 0.350" thick, It is about .040" clear of the gear dogs when new. It will stop working when there is no gap left.
The very best baulk rings were the forged steel ones made up until ~1970. These had forging lines and sometimes cutter marks on their periphery.
Since then, most are pressed in a sintered powder process, some are better made than others.
You can grind .020" off the FLAT face of the ring that goes towards the gear, to get more life. provided it is at original thickness.
Helical drop gears are fine (and quiet!) on a road car, I've not had any problems at all.
Just check the primary gear and idler gear end floats are within spec, I use .004-.005" for both.
If assembled much too loose, the end thrust can wear the gearbox case or break the primary gear's bronze thrust washer.
PostPosted: Sun May 18, 2014 11:39 am
Thanks for the info Doc. Your a big help.
5/72 Clubman Gt
PostPosted: Sun May 18, 2014 11:45 am
If rebuilding the gearbox I put new idler bearings in unless changed recently.
They are cheap. But if neglected and they wear right out it can stuff the flywheel housing, the gearbox case or both.
PostPosted: Wed Jul 02, 2014 9:28 pm
Another gearbox related question, does anyone know what comes in the gearbox bearing kit from Karcraft? Its only $150 odd dollars. When you look at bearing prices from other suppliers it seems really cheap. I need to replace every bearing as it had bearing failure that went through the whole engine :(
I would have to buy diff bearings and idler bearings also but want to make sure I get everything required. Cant just go down the road and get a forgotten part down here.
5/72 Clubman Gt
PostPosted: Wed Jul 02, 2014 10:52 pm
I know it includes all the gearbox bearings, but not the 2x idler gear needle rollers. They are extra.
I am not sure about the 2x diff bearings, I think they are extra also. Ring and ask. :wink:
PostPosted: Wed Jul 02, 2014 11:00 pm
On tomorrows to do list.
5/72 Clubman Gt
PostPosted: Thu Jul 03, 2014 8:06 am
Slight thread detour,
any comments, thoughts experience with the new roller type idler gear bearings available now fromMed/ Swiftune ( each slightly different i think)
PostPosted: Thu Jul 03, 2014 10:07 am
I asked them the same thing a few weeks ago:
MSG20 G/BOX OVERHAUL KIT - MINI (4 SP SYNCRO)(NO DIFF PARTS) 1.9000kg
13H7848 <B> BEARING - IDLER GEAR - MINI - ALL SYNCRO
HYL8473 <A>. BEARING - VARIOUS - LAYSHAFT - MG MIDGET+MINI (ROLLER) x 1
HYL3616# <B> GASKET SET - SUPPLIMENTRY - MINI x 1
HYL3614 <B> GASKET SET - G/BOX - MINI x 1
22G931# <B> LAYSHAFT - MINI (ALL SYNCR)(UK MADE)(64 ROCKWELL) x 1
AAU1365 <A> BEARING - MAINSHAFT - MINI (DOUBLE ROW) x 1
ADU7619 <A> BEARING - 1ST MOTION - MINI - ALL SYNCRO x 1
HYL8474 <A> BEARING - 1ST MOTION - MINI - 3 SYNCRO+ALL SYNCRO x 1
CHM141 <A> BEARING - LAYSHAFT - MINI - ALL SYNCRO (ROLLER) x 2
22G2033 <B>. BAULK RING - VARIOUS - AH SPRITE+MINI x 4
PostPosted: Thu Jul 03, 2014 10:33 am
Timmy that's the gearbox overhaul kit you listed.
The bearing kit `KIT4SYNCHRO' has no idler bearings, I bought one recently.
PostPosted: Thu Jul 03, 2014 11:28 am
Oops. It's the $330 kit less diff parts. If you were doing a gearbox overhaul you might need the rest of these bits anyway :P
PostPosted: Thu Jul 03, 2014 3:07 pm
at least get a cross pin diff - a new "competition" diff pin and new spider gears still isn't as good as the originals... they'll wear out pretty quickly and start shoving crap through your motor
PostPosted: Thu Jul 03, 2014 9:46 pm
So I rang karcraft and got the info I required. Thought it was to cheap to have all the bearings for the gearbox.
5/72 Clubman Gt
