It is currently Tue Aug 12, 2025 8:51 am
 Post subject: Door hinge help!
PostPosted: Thu Jul 17, 2014 8:27 pm
Hi guys , I'm up to the stage of putting the doors back on but I've hit a road block , I am unable to read the markings on the back of my hinges as where to put them , is there any way to know what position ( upper, lower, left or right ) to put them ?
Cheers Jarrad
 Post subject: Re: Door hinge help!
PostPosted: Thu Jul 17, 2014 9:17 pm
http://www.drjing.com/Mini/TechFiles/HingeRebuild.htm
http://www.drjing.com/Mini/Images/Tech_ ... geCode.JPG
Hope the second link helps ya
PostPosted: Fri Jul 18, 2014 9:03 pm
The numbers embossed on the hinge parts as pictured in the second of drjbeam's links are for UK sourced hinges. Those manufactured in Australia should have UL & LL (upper and lower left) and UR & LR (upper and lower right).
PostPosted: Fri Jul 18, 2014 10:22 pm
Thanks guys I'll try again at reading the markings
PostPosted: Tue Sep 01, 2015 1:52 pm
I came back looking for this today when pulling apart some hinges, both these links are very good. Probably worth adding to the How To section about working on doors.
PostPosted: Tue Sep 01, 2015 2:39 pm
It's on my internet explorer favorites list in a folder named mini on my computer
PostPosted: Tue Sep 01, 2015 3:55 pm
Bits of the old cardboard gasket can sometimes cover up the letters.
PostPosted: Tue Sep 01, 2015 4:27 pm
If you can't make out the letters,
The ones with the big angle outwards are top ones.
The ones with the slight angle inwards are bottom ones.
Users browsing this forum: No registered users and 216 guests
