It is currently Fri Jul 18, 2025 1:22 pm
 Post subject: Mk II 'S' Engine Colour
PostPosted: Tue Jul 15, 2014 9:37 am
What is the name of the colour used on MkII engines? I seem to recall "BMC Gold" Talking to Ron Williams at Tenterfield last year, he says there is a Valiant colour called Tiffany Green is pretty close to the BMC colour. Does anyone have a paint code or direct me to a previous post. Thanks!
PostPosted: Tue Jul 15, 2014 9:48 am
`Cooper S green metallic'. It is a spraying enamel. John Smidt stocks it.
PostPosted: Tue Jul 15, 2014 11:32 am
Thanks, I see MiniSport have it at $45.00 a tin. What is Johns web address?
PostPosted: Tue Jul 15, 2014 11:56 am
LINK also sell it in a spray pack. It's also a Mitsubishi colour and that's what the can reads. :shock:
Gives me a thought for a new thread!
PostPosted: Tue Jul 15, 2014 12:55 pm
http://minikingdomonline.com.au/
PostPosted: Sat Jul 19, 2014 4:23 pm
We have just completed a rebuild on a Cooper S original engine and the owner wanted as close to original on the colour. Couldn't get the mix in an enamel so went with a COB (2K Clear over Base). From memory there are 7 tinters in this and while most ones that are close have a lot of silver, this mix has silver with a hint of orange and gold.
After a lot of searching and trials we came up with this:
We used a 'BASLAC' basecoat 35 with a clear on top. AMBER SHERWOOD F3 is a 1970 Dodge colour and most companies should have the same comparable mix.
Dave K.
PostPosted: Sat Jul 19, 2014 4:27 pm
Thanks Dave, I just shrunk the images down a little to a size that fits the screen a little better.
They were massive. I've just pulled them across to the Ausmini Photobucket, so the links aren't the same
PostPosted: Sat Jul 19, 2014 4:31 pm
The colour is really bright as it comes out of the gun, but it tones down to a much paler colour as it gets a little heat over the next few months.
Your colour looks much the same as the Mini King tint, so this image of mini today might represent well what I am talking about.
PostPosted: Mon Jul 28, 2014 10:30 am
Hey Mick can you tell me where you got those type of hose clamps from?
1993 R32 Nissan Skyline GTR
PostPosted: Mon Jul 28, 2014 10:33 am
The old wire ones?
They're the wrong ones for my car, but I got a kick out of fitting them, and I haven't had an excuse to take the hose off to fit the utilux ones instead...
I think I found them over time and had them zinc coated along with a batch of bolts. I think John Schmidt at Miniking used to sell them from time to time however. Give John a call.
PostPosted: Mon Jul 28, 2014 11:18 am
They still make those wire hoseclamps in USA.
PostPosted: Mon Jul 28, 2014 7:25 pm
MG heritage spares at Smithfield sell them
1969 Cooper S
PostPosted: Tue Jul 29, 2014 2:01 pm
Thanks Mick, Doc and Fordboat
PostPosted: Tue Jul 29, 2014 4:49 pm
The correct Cooper S engine colour on an old Duco tin I have (never throw anything out) is Metallic Green - Duco colour code 203-13261.
203 is the paint type, in this case High Gloss lacquer, and 13261 is the colour code.
RonR
68 build Mk1 Cooper S
PostPosted: Tue Jul 29, 2014 4:57 pm
Good to know! Thanks Ron.
