It is currently Thu Aug 21, 2025 8:35 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sat Jul 19, 2014 9:39 pm
GB1275 wrote:
My Lukey L-132:
cool
PostPosted: Sat Jul 19, 2014 10:12 pm
TK wrote:
so you have music coming out of your tail pipe? Spoilt it Mick.
It was an option from Lukey.
PostPosted: Sun Jul 20, 2014 6:49 am
Mick wrote:
I changed out the RC40 for the Lukey today, but not before attaching my Contour HD Camera to the hydro pipes facing the rear apron.I took it up the road for a blast before and after the muffler change over. It took about 30 minutes to change out including trimming a piece of 44 mm pipe to the right length.I used a piece of 44 mm pipe bent up with an exact 30 degree bend in the center and I trimmed it to suit.
The run is out of my place and up a really long steep climb up the range nearby, turns around and then home again. The Lukey sure does have a bark, that's apparent straight away. Still good inside the car, and much the same under high load, as in up the long hill nearby, just that it now has a growl to the exhaust that wasn't there before. Sounds good and I'm pleased.
Thanks for taking the time to do this Mick, much appreciated.
The video with the Lukey installed sounds much better to my ear.
PostPosted: Sun Jul 20, 2014 7:36 am
The middle of the vids are just exhaust now. The Norwegian Electronica option has been turned off.
PostPosted: Sun Nov 29, 2015 8:14 am
Can't seem to find the video links to this :(
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sun Nov 29, 2015 9:20 am
Worked for me?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
Users browsing this forum: No registered users and 185 guests
