It is currently Sat Jun 21, 2025 3:37 am
PostPosted: Mon Jul 21, 2014 8:50 pm
The flare - it's a lot!
PostPosted: Mon Jul 21, 2014 9:48 pm
But what flare? (sorry if it's already mentioned)
As I mentioned above, in NZ some tyre sticking out is just fine, as long as the tread is covered. I would think 10-12mm would be all smooth sidewall? The wheels being asked about are even more + offset, so should be more tucked under.
http://www.mini-hb.co.nz
PostPosted: Tue Jul 22, 2014 7:39 pm
Standard group 2 flares.
PostPosted: Wed Jul 23, 2014 11:41 am
Hmmm all things to consider... I doubt i'll need anything like Miglia flares, but the thought is nice, especially Curley carbon ones :P
Going down for a trial fit with just a rim on the car, no tyre, dropped on a block of wood, and i'll be able to work out roughly where they'll sit with an extra 10mm or so in width from the tires.
I've got 99 problems, and my Mini is all of them.
PostPosted: Thu Jul 24, 2014 6:55 am
Has anybody fitted 155/70/12's to a mini before? Pretty much the only tire I can get that's readily available.
