It is currently Mon Jul 21, 2025 4:10 pm
 Post subject: mini matic?
PostPosted: Sun Jul 27, 2014 9:15 pm
Got a yma2s4 this arvo but engine no plate is 99hh119/H559.
Is that correct eng no for an auto?
Thanks.....
Now with 2 extra ports!
 Post subject: Re: mini matic?
PostPosted: Sun Jul 27, 2014 9:25 pm
Manual blocks can not fit on auto gearboxes so if the engine is fitted to a auto box then it's an auto.
PostPosted: Sun Jul 27, 2014 9:27 pm
Eng in car is an 1001...... clubby 1100? The 99hh no. Is on the id plate......id have thought 99hh would be a deluxe 998 motor?
PostPosted: Sun Jul 27, 2014 9:37 pm
99H119/H559 is a Matic motor. They were fully imported so they use the UK prefix codes.
The Deluxe had 9YA/Ta/H motors.
PostPosted: Sun Jul 27, 2014 9:45 pm
Oh ok......thanks morris 1100....
PostPosted: Sun Jul 27, 2014 10:58 pm
All the MiniMatics (except maybe the earliest) had a 99H/119/H motor I think. Mine is 3/70 and had one.
Note the Mk2 Matics (with the K dash) are YA2S5, not YA2S4.
PostPosted: Mon Jul 28, 2014 10:45 am
Your car should be a YMA2S4 approximately 1800 based on the data I have. Does it have a model stamping in the radiator shroud?
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Mon Jul 28, 2014 11:08 am
Body No is 2014.
PostPosted: Mon Jul 28, 2014 11:49 am
Is mine one of the really early ones or something?
Untitled by Chux007, on Flickr
PostPosted: Mon Jul 28, 2014 2:29 pm
1194 is early being the 694th matic built
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
PostPosted: Mon Jul 28, 2014 5:08 pm
I think they built around a thousand cars with the first batch of imported engines, these numbers seem to be issued randomly like the Cooper S, low numbers cars have high numbered engines and vice versa.
Somewhere between car 1519 and 1735 they changed from the 9AN/AH/ engines to the 99H/119/H engines.
I think they changed the codes in the UK plants after Leyland took over around the middle of 68.
PostPosted: Mon Jul 28, 2014 5:59 pm
Mine is
Engine number: 99H119/H/365
Body number: 1606
PostPosted: Mon Jul 28, 2014 6:17 pm
That narrows it down further. And it also helps date the cars (I just need the date that the UK changed the code!).
Some people try to say that 99H119/H/ means mk2 Matic.
PostPosted: Mon Jul 28, 2014 6:38 pm
hmmm, what would mine be then please Morris 1100?
Engine No: 99H119H1009
Body No: 2497
1968 Mini-Matic
PostPosted: Mon Jul 28, 2014 6:56 pm
My Mum bought a brand new matic on the 22/5/1968, I have scanned the original purchase document and the original registration certificate and noticed the engine number is recorded differently on both, the purchase document says 9ANAH 150 where the rego says 99H119H150 who knows.
