It is currently Thu Jul 17, 2025 7:35 pm
PostPosted: Sun Aug 03, 2014 9:14 pm
Does anyone know the I.d of the centre cap hole in the contessa alloys. I'm in UK and have found some 60mm GB caps that I think might fit!!
Thanks
PostPosted: Sun Aug 03, 2014 9:25 pm
Depends on which wheel you have, there's different sizes.
The earlier ROH Contessas are 67mm measured off the caps I have here.
PostPosted: Sun Aug 03, 2014 9:33 pm
They are s offset with 1/77 on the inside. Cheers
PostPosted: Sun Aug 03, 2014 10:52 pm
Rover Cooper
try sticking a Coke can in the centre, that works fine for my spare set of wheels,
PostPosted: Mon Aug 04, 2014 1:56 am
I've heard of this before, pressure pack can lids, mortein and such also fit but I'm looking for something a little classier :))
PostPosted: Mon Aug 04, 2014 10:46 pm
Like these???
I made 4 once on my bench lathe, not making more, but I'm sure someone could churn them out on a bigger lathe or a CNC one.
Material was black HDPE plastic. Depth inside has to clear the hub nut & split pin.
They are now on a friend's Cooper S that is seldom driven.
PostPosted: Sat Aug 09, 2014 4:03 pm
Defiantly classy stuff Doc. :) Don't forget my rocker cover next week :) how much did we agree on again? Richard .
PostPosted: Sat Aug 09, 2014 4:16 pm
PM sent.
