It is currently Tue Aug 19, 2025 1:09 am
 Post subject: Pictures of this heater.
PostPosted: Sat Aug 09, 2014 7:37 pm
Hi guys,
I bought this heater today hoping to repair it and fit it to the car.
Has anyone got photos of the same model heater mounted in the car?
I am still unsure where exactly you mount them.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Sat Aug 09, 2014 7:45 pm
It can mount on any surface, as long as there is a gap behind it to let the air circulate.
Just screw it to the firewall below the dash.
They were a very common accessory heater in the 60s.
PostPosted: Sat Aug 09, 2014 7:48 pm
PostPosted: Sat Aug 09, 2014 7:57 pm
that is where mine fits in my 65 panelvan
65 panel van Sprog
73 panel van Iggy
PostPosted: Sat Aug 09, 2014 8:03 pm
Thanks for the quick reply.
I will attempt to repair the bakerlite/ plastic shroud with fiberglass and casting resin.
PostPosted: Sat Aug 09, 2014 8:11 pm
There is one fitted to my brothers duluxe under the switch panel
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Sun Aug 10, 2014 11:48 am
They were standard fit to some mk2's I believe. When they ran iut of the other heaters they used what was available
PostPosted: Sun Aug 10, 2014 9:58 pm
When you think about it,...... I would have to say that the Mk2 had the biggest range of heaters.
Early Mk2 cars (1969) had the left over metal Mk1 style.
Then in 1970 they changed to the moulded Mk2 heater.
When these ran out they started using the bullet/beehive heater as shown above in late 1970.
Finally some of the last Mk2 cars in early 1971 were fitted with the Clubman style heater.
Now that is a impressive range for one model.
Correct
Users browsing this forum: Bing [Bot] and 313 guests
