It is currently Sun Jun 22, 2025 4:33 am
Post new topic Reply to topic  [ 411 posts ]  Go to page Previous  1 ... 22, 23, 24, 25, 26, 27, 28  Next
PostPosted: Thu May 08, 2014 9:42 am
Archangel007 wrote:
That might come up ok Dan if you get it covered or something...??
Yep that would make it look ok. It's not too bad as it's along the theme of that bare bones look at the moment
Life's a garden.... Dig It!
PostPosted: Fri May 23, 2014 8:04 pm
Something little but another step forward. Well it should have been done originally but done now. Will get it ceramic coated again
PostPosted: Fri May 23, 2014 8:20 pm
Give Ash some flowers Nick .
Bit of an oversight by the PO! As you say, at least it is done now and it is one less thing to worry about during reassembly.
PostPosted: Sat May 24, 2014 5:54 pm
Any progress is good progress Dan!
PostPosted: Sun Aug 03, 2014 5:27 pm
Progress is progress!
PostPosted: Sun Aug 10, 2014 6:16 pm
Sorry for the crappy photos...
Wiring up a few switches and gauges takes longer than it should
I think they look mini worthy
PostPosted: Sun Aug 10, 2014 10:43 pm
I'm just about ready to do the gauge senders into the 4efte. I've had a quick search and look but nothing easy surfaced... In the motor I have, there are 3 senders in the water. One looks like it's for the ecu and the other 2 have nothing on them. Does anyone know if one or both can come out?
Similar question for the oil (I'm doing an oil temp and oil pressure) is there anywhere particular they should go?
All the gauges I'm using are electric at least so I don't have to run any mechanical lines into the cab.
Thanks in advance guys!
PostPosted: Tue Aug 12, 2014 8:17 am
Thats a really clever idea to mount those toggle switches there, looks like a factory installation.
PostPosted: Tue Aug 12, 2014 8:47 am
Thanks bud, I've still got a mini switch panel but I think I will stick with this set. Not real sure what I'm going to use all the switches for yet but I'm sure I'll find something
PostPosted: Sun Aug 24, 2014 3:19 pm
I think this looks a little better...
PostPosted: Sun Aug 24, 2014 6:52 pm
Looks good Dan...
PostPosted: Sun Aug 24, 2014 8:51 pm
Nice one
PostPosted: Sun Aug 24, 2014 8:56 pm
Hopefully doing some more wiring this coming weekend...
Would be nice to get it to the stage of being ready to fire up. Will just need to replace all oils and fill all fluids. Then continue the wait for driveshafts :roll:
PostPosted: Mon Aug 25, 2014 10:54 am
Dan,
Have a look at the wiring doc that I created a couple of years ago. Pg 12 shows the functions of the 3 coolant switches aruond the thermostat (HVAC, ECU, Dash gauge, Rad fan)
http://www.mearcat.com.au/docs/EP82%20Starlet%20Wiring%20and%20Connectors.pdf ~10Mb
-Alan
PostPosted: Mon Aug 25, 2014 7:34 pm
Mearcat wrote:
Dan,
Thanks bud, I have had a look at that at some stage... Better have a better read through it
Users browsing this forum: No registered users and 25 guests
