It is currently Fri Jul 18, 2025 2:05 pm
Post new topic Reply to topic  [ 122 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
 Post subject: Re: Car trailers
PostPosted: Sun Aug 24, 2014 7:46 pm
Yep wheel chocks were added after the trailer was built , now the car is quick and easy to tie down every time and never comes loose even when it's only tied down at the front
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Sun Aug 24, 2014 9:18 pm
Has anyone used one of these Raceking trailers?
http://www.raceking.com.au
PostPosted: Sun Aug 24, 2014 9:29 pm
Looks like a very nice trailer. Especially being able to lift it up high to work underneath. Hope it has a remote for the hydraulics otherwise it would be difficult to open the door to get out!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Aug 24, 2014 9:36 pm
Base model is hand pump so you have to climb out the window or alternatively push the car on, it is only a 4 degree ramp angle. If you want remote add $$$ I looked at an automated version in a different make and it was more like $8000 :cry:
PostPosted: Sun Aug 24, 2014 10:13 pm
http://www.loadsafetrailers.com/. Same trailer as http://www.raceking.com.au/
It looks like Richard has found someone to market his design. Go direct to Loadsafe and take out the middle man
PostPosted: Sun Aug 24, 2014 10:24 pm
I thought it looked like the one you suggested.
5/72 Clubman Gt
PostPosted: Mon Aug 25, 2014 5:27 am
There's a few designs of those around: http://www.renegadetrailers.co.nz/car_transporters
The new design of these guys no longer has the overhead arm, it's all in the frame. NZD$6500 for 3m X 1.6M with all the trimmings and electric lowering.
http://www.mini-hb.co.nz
PostPosted: Tue Aug 26, 2014 11:27 am
Found A custom made trailer in Adelaide if anyone is interested
http://www.my105.com/ListingDetails/tab ... fault.aspx
PostPosted: Tue Aug 26, 2014 1:15 pm
I looked at that one and unfortunately you can't open doors when the car is on the trailer, it was made for a race car which had no doors so the guy selling it said he never thought about it :smile:
PostPosted: Tue Aug 26, 2014 1:39 pm
If you stick a winch on the trailer you don't need to open the doors. :lol:
PostPosted: Tue Aug 26, 2014 3:41 pm
Yeah who uses a handbrake when towing anyway :wink:
PostPosted: Wed Aug 27, 2014 2:28 pm
Just to correct some misinformation in this thread. 10" Light Truck tyres are still available for around $100-120 each. They are commonly used on boat trailers. A tandem running 10" light truck tyres would be fine for towing a Mini.
I've had this single axle trailer for a long time. It cost me $800 at Geelong swap meet and was previously used to tow a sprint car. Weight is 450kg with the ramps on. Fits a car up to the size of a Gemini or Corolla. The only problem is opening the doors, as others have mentioned. I have to winch the sliding window UK Mk1 Austin on. The ramps are really heavy too, I really should buy/make some lighter ones.
This trailer has It's seen more of Aus that I have, being lent to various trusted people for trips interstate and even to Tassie. It is now in dire need of a blast and repaint. Keep in mind these photos were taken April 2006 and it was starting to look a bit daggy then.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Aug 27, 2014 6:32 pm
I also love Beanies trailer but the delivery from SA to Qld is prolly gunna cost a fortune
PostPosted: Wed Aug 27, 2014 8:15 pm
Here is mine, doors can open, sump clears front and its easy to move
www.facebook.com/sydneyminis
www.facebook.com/miniowners
www.sydneyminis.com
1969 Morris Mini K- 1380cc for driving
1969 Morris Mini K Panel Van- 1098 for loads
1971 Morris Mini K Panel Van- Still in the barn
2000 Rover Mayfair- Luxury
PostPosted: Thu Aug 28, 2014 1:43 pm
Trailer. I have one of those. Single axle, no springs, cable brakes. Rated to 1250kg GVM as far as I remember. Don't know how much it weighs, though it's light, but I wouldn't put more than 1000kg on it.
Here it is with my fathers A40 Devon after he blew the head gasket on his way to work one morning.
It also went and picked up a bug eye Sprite a fortnight ago. It went to Hay this year, although I didn't. :(
It's great, except the ramps are rubbish.
Users browsing this forum: Bing [Bot] and 125 guests
