It is currently Sat Jul 19, 2025 3:25 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
 Post subject: 1.75 inch SU ram tube
PostPosted: Tue May 17, 2005 10:35 am
Does anyone know where I could buy a small ram tube to fit inside an offset Ramflo air filter for a 13/4 inch SU?
PostPosted: Tue May 17, 2005 8:24 pm
Not much room-
You could get one turned up from alloy. Similar to my Dellorto/Weber stubstacks. Just need to sketch it up.. :wink:
PostPosted: Tue May 17, 2005 9:44 pm
You could try Midel...02/9758 1966 ask for Silvo...Say Ausmini Sent you :wink:
PostPosted: Tue May 17, 2005 9:45 pm
They won't have anything short enough. Bugger-all room in an offset Ramflo..
PostPosted: Wed May 18, 2005 6:40 pm
i got a hp filter for $75 that has a alloy turned base like what dr mini is talking about in it. check it out here http://www.hi-flow.com/HPAirFilters.htm
not a lot of room with their base model filter about 2 - 3mm between in and the firewall and it protrudes in to the speedo cut out a fair amount. but the quality is fantastic. and it performs quite well. i'll be getting the k & n filter to replace the paper element in there at the moment, should go even better then too.
cheers steve
edit: there might be more room with a shorter manifold, mine is a minisport one don't really know how this compares with others for length.
Cheers Steve.
1973 south african mk3, 1275 +30 (1300), RE13 cam, hif44, mildy worked head with s sized valves, pulsar dizzy, 1.5:1 minispares forged rockers.
PostPosted: Wed May 18, 2005 7:47 pm
Ok this is what I have, Graham Russell inlet on a 13/4 inch SU on a 030, 1275 in an 1972 Mini Moke. The offset Ramflo is already on its way. If anyone could make them they would have a market because lot's of us use the offset Ramflo's, Doc?
PostPosted: Wed May 18, 2005 7:53 pm
Yeah I could make you some, but I need dimensions of carb bore (measure it!) and filter mounting bolt sizes/spacing. :wink:
PostPosted: Wed May 18, 2005 10:15 pm
Don't forget I have a HIF44 and I would also take one Dr :wink: althought the List I have with you already
It's not to far similar to..to the delly one's I have :wink:
PostPosted: Wed May 18, 2005 10:16 pm
I think the Dr needs additional patiance to provide the Goverment medicare grant
Anyone else
PostPosted: Thu May 19, 2005 7:36 am
I'll get the measurements Kev
 Post subject: .
PostPosted: Thu May 19, 2005 8:28 am
Yeh ill take one too... gettin a HIF44 fitted within the next week... interesting to see how it will go compared to twin 1.25 su's....
next we see about a sc12 on her
PostPosted: Thu May 19, 2005 9:22 pm
Did Vizard go into the flow tests he did on ram tubes in his books. He wrote an article in CCC on this and there is more to it than just making a tube that looks right.
Chris
Everything I like is either
PostPosted: Thu May 19, 2005 9:52 pm
Mine is a (poor) copy of Vizard's #11 one, shown on p57 in his chapter `Ram Charging'. Tuning BL's A series engine, Rev 2.
It's not a tube, it's a 4.5mm thick radiused entry that lays back at 120* to the filter backplate. Yes it works on Webers & Dellortos, should do the same on an SU.
Here's a pic.. :wink:
The one outside the box is a 45mm, close to what an HIF44 one would look like.
PostPosted: Fri May 20, 2005 7:00 pm
OK Kev the id of the ramflo/carb hole is 44.5mm.
The bolt holes that hold the airfilter backing plate to the carb are 72mm apart.
Thanks mate
Just email the man with the disc backing plates on the cheap ;0)
PostPosted: Fri May 20, 2005 7:18 pm
Thanks mate
I guess you mean 72mm centres.. what diameter are the bolts- 5/16"?
Also... how far from the bottom edge of 44.5mm carb inlet hole, to the bottom of the Ramflo filter backplate (inside measurement)?
Users browsing this forum: No registered users and 25 guests
