It is currently Fri Jul 25, 2025 10:56 pm
 Post subject: Camshaft drive type
PostPosted: Sun Sep 07, 2014 6:10 pm
Hi all, this is my camshaft pictured below. Where can I get an oil pump to suit?
Cheers.
 Post subject: Re: Camshaft drive type
PostPosted: Sun Sep 07, 2014 6:18 pm
Easy enough to get the pump (spider drive). You will also need the spider drive coupling which adapts the oil pump to the cam shaft.
This is the coupling:
http://www.minimania.com/images_temp/80 ... CHM108.JPG
To suit this pump:
http://www.minispares.com/image.axd?typ ... GLP141.jpg
PostPosted: Sun Sep 07, 2014 6:25 pm
I've seen the spider drive pumps but not the coupling.... Looking on the interweb I only found one on Minimania, are there any suppliers in Aus for the adapter? Thanks
PostPosted: Sun Sep 07, 2014 6:27 pm
I had a look as well. I thought there would be a few more with these in stock.
The doc was making them a while back, but I reckon they would be common second hand.
PostPosted: Sun Sep 07, 2014 6:29 pm
Someone might have one in a bucket of bits and don't have a use for it :) :)
PostPosted: Sun Sep 07, 2014 7:29 pm
i have a few of them
Matt
Bne
0407 135 656
(07) 3399 99 99
PostPosted: Sun Sep 07, 2014 7:36 pm
Matt
Bne
0407 135 656
(07) 3399 99 99
PM sent :)
PostPosted: Sun Sep 07, 2014 7:44 pm
I have the spider to slot drive ones new, these have a slot inside instead of a spline. Laser cut from 8mm steel plate.
They take the 1275A+ slot drive pump.
PM me if you want one, but Karcraft and TheMiniMan both stock them too.
PostPosted: Sun Sep 07, 2014 10:05 pm
The Mini King
And Mini Kingdom Online
PostPosted: Mon Sep 08, 2014 8:38 am
Thanks John, I forgot you have them too. :oops:
re the original star ones with the spline inside, AFAIK they are NLA new everywhere now, except possibly from APT Fast in the states.
But I just searched their site and can no longer find them.
www.aptfast.com
PostPosted: Mon Sep 08, 2014 3:29 pm
i have both the std spider drive piece & the good Docs adaptors in stock,,, which would you like
& yes i got your PM, but you just asked how much$?...
which one would you like?
Matt
PostPosted: Mon Sep 08, 2014 3:56 pm
Matt
I'll just call next time, not PM. Cheers
Users browsing this forum: Bing [Bot] and 113 guests
