It is currently Sun Jul 27, 2025 2:23 am
PostPosted: Tue Apr 20, 2004 10:33 pm
Dewey,
Revolution Racegear sell spare keys for their battery switch, not sure if the same as the Supercrap Auto ones, might be worth a check.
PostPosted: Sun Apr 25, 2004 12:23 pm
Hey,
Just wondering if somebody can give me a run down on how the pulley comes off so I can remove the timing cover. The shop manual is typically vague...
I've had a go at putting a screw driver in the flywhell ring teeth so that the the crank doesn't turn when I try to undo the bfo bolt that holds the pulley on... no luck as yet
tips would be great :-)
dewey
dwightgunning.com
PostPosted: Sun Apr 25, 2004 5:36 pm
I put an old bearing half shell into the ring gear teeth in the starter hole- the shape of the housing holds it in there. Safe to 200 Lb/ft or more torque- better than a screwdriver or jemmy bar... :wink:
<edited> typo..
Last edited by drmini in aust on Sun Apr 25, 2004 7:16 pm, edited 1 time in total.
PostPosted: Sun Apr 25, 2004 6:34 pm
yeah something other than a screw driver would be more useful.
I was mainly concerned that I might be doing it completely wrong
dewey
dwightgunning.com
PostPosted: Mon Sep 22, 2014 9:13 am
So...did the flywheel come off OK? Finished Uni yet? :lol:
PostPosted: Mon Sep 22, 2014 10:41 am
I have made my own puller using a flywheel.
I got a flywheel with a removeable centre welded a big ass nut inside for a big ass bolt. Then drilled the three existing holes out to take the bolts to screw into the flywheel.
I leave the crankbolt in to "catch" the flywheel when it breaks free.
20 mins work. Looks legit and works extremely well.
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
