It is currently Tue Jun 24, 2025 6:52 pm
 Post subject: New 1275 project
PostPosted: Sun Sep 28, 2014 6:44 pm
Gday team!
Got myself a A+ 1275 on Friday! :D I know nothing about engines or rebuilds but have a friend to step me through when I get stuck.
My plan is to pull it down and slowly rebuild it and learn a heap on the way.
Question what bolts do I need to go in the clutch cover holes? I have borrowed a engine trolly off a friend that will make it so easy. But I need to buy some bolts to screw engine to trolly.
IM SOOOOOOO EXCITED!
 Post subject: Re: New 1275 project
PostPosted: Sun Sep 28, 2014 7:12 pm
ALL the threads in the gearbox are UNC. The clutch cover [ aka wok] ones are 5/16 UNC.
BTW the engine block threads are all UNF, except the head stud holes which are 3/8 UNC.
And 7 stud holes in the top of the head are UNC also.
[edit] as are the fuel pump and oil filter stud holes...
The rest are UNF. :P
Last edited by drmini in aust on Sun Sep 28, 2014 9:21 pm, edited 2 times in total.
PostPosted: Sun Sep 28, 2014 7:16 pm
Thanks Doc!!!!
PostPosted: Sun Sep 28, 2014 7:18 pm
http://www.ausmini.com/forums/viewtopic.php?f=25&t=67980
Worth reading several times brilliant stuff :D
PostPosted: Wed Oct 01, 2014 11:59 am
So I hope this post works!
Today I started pulling the engine down. Found myself a brilliant mechanic near where I live. He got me the engine and appreciates why im doing it. So he said go home pull it all down and take the head block and pistons back and we will go from there.
Ill try to take photos and update things as I go if anyone thinks they could be bothered reading it!
First question I have removed all the nuts on the top of the head (But not touched the running gear). The head is well and truly stuck to the block. Do I just bash it with a hammer to separate it?
PostPosted: Wed Oct 01, 2014 12:59 pm
You can use a compothane (Hard plastic) hammer. Dont use a screwdriver on the sealing surfaces. Also try putting some string into no 1 cylinder on the compression stroke.
PostPosted: Wed Oct 01, 2014 2:28 pm
Make sure you have loosened all the rockers so they can all wiggle, remove the rocker assembly in one piece, then lift out all the pushrods. Head bolts out, Then you can give the head a bit of a tap with a block of timber and hammer.
PostPosted: Wed Oct 01, 2014 3:50 pm
Whoops well I didnt do that!!!!!
PostPosted: Wed Oct 01, 2014 4:03 pm
Whoops well I didn't do that!!!!!
If you got it off anyway don't worry, just loosen off the adjusters before you assemble it, otherwise it puts stress on the shaft and can bend. Also there is a sequence to tighten the bolts but that's for another day.
PostPosted: Wed Oct 01, 2014 9:54 pm
Did you take the rocker cover off and undo the nuts in there? Another 4 head studs in there to hold on!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Thu Oct 02, 2014 12:32 pm
Yep I did. Pretty sure im up to the bashing part!!!!! Packed up yesterday will try again this afternoon
PostPosted: Thu Oct 02, 2014 2:00 pm
Just tried to loosen the head by turning engine upside down then placing a block of timber on it and whacking it with hammer. No joy! :cry: Will see if I can phone a friend lol
PostPosted: Thu Oct 02, 2014 4:05 pm
2 of the head studs- the middle front, and one of the back ones, are a neater fit in the head than the others. They can rust in on old engines left for years.
Spray them with WD40, then use 2 locknuts to screw those 2 studs out, if possible.
PostPosted: Thu Oct 02, 2014 4:07 pm
Let me at it.... I'll get the bloody thing off :)
PostPosted: Sat Oct 04, 2014 4:12 pm
WINNING!!!!
Its done and ready to return to the mechanic. We will then both decide where to from here!!!!
