There is a car that's just been added to the Mini Cooper Register that I think is close to the delivery date of yours, but I can't be sure as the numbers on your ID plate aren't clear enough in that picture. It's the same colour, Cherry Red and Smoke Grey. If you wish to send me a PM with a clearer picture of the ID plate, or even the stamped data from it in text form I can verify for you.
Well done on acquiring another rare car and helping to preserve its history.
Be aware the wide gap in the centre of the seat pleats mean the seats are probably from a later model Mini. I believe your Cooper should have equally spaced pleats, but I'm happy to be corrected.
Goldbrocade_62 wrote:
Not the early ones
That's right. Just had a look at Graham Russell's 'new' Cooper today and noted no ventilated fuel pump hole. Apparently the early Coopers had a different pump with no breather.
P.S. Graham talks about his Cooper near the end of the second page of this thread. You can see his car number and colour combination.
viewtopic.php?f=2&t=87354
