It is currently Tue Jul 22, 2025 1:46 pm
PostPosted: Thu Oct 16, 2014 5:09 pm
Getting the final set up on my car done and with just 1 degree caster the front wheels (10X6) are very close to fouling the front of the arch when on full lock.
1 degree doesn't cut it, has zero self centering, but if I aim for the 3 or 4 or whatever is recommended, the wheel will shift further forward, yeah?
Anyone any idea how much the wheel will shift forward with a 2 or 3 degree increase in caster?
http://www.mini-hb.co.nz
PostPosted: Thu Oct 16, 2014 9:09 pm
Postive caster means the bottom of the hub trails the top...so, as you increase caster, the wheel moves back.
4 to 5 deg is what you want.
Cheers, Ian
PostPosted: Fri Oct 17, 2014 6:30 am
Cheers, Ian
errmm...not from my learnings.... :roll:
I guess I'll find out for sure this arvo, got it booked into a mini alignment guru.
PostPosted: Fri Oct 17, 2014 6:53 am
I learnt positive takes lower point forward.
Anyway, if the tyre does touch you can cheat a smidgen by putting spacers in frame. I did that with mine, got about 10mm extra, without problem.
PostPosted: Fri Oct 17, 2014 8:02 am
