It is currently Wed Aug 06, 2025 10:40 pm
PostPosted: Sun Oct 12, 2014 1:51 pm
Thanks for the contacts Michael
This should stop any errant shavings going anywhere.
PostPosted: Sun Oct 12, 2014 8:53 pm
rebuild time, it looks like crap to me
PostPosted: Mon Oct 13, 2014 8:45 am
hard to make a call on the quality of the cleaned bore from picture, does num 2 have a big scratch also?..
PostPosted: Mon Oct 13, 2014 8:50 am
@Mick and others,
be aware the ACL Monotorque smallbore gasket is no more, since ACL went belly up. :cry:
I'm not sure what one now is/was 2nd best, if somebody knows please post it here.
I wonder what gasket the 998/1098 turbo dudes are using now.. as the ACL Monotorque was da bomb for these.
PostPosted: Mon Oct 13, 2014 2:28 pm
There's a place in St Mary's (TJ's or Teejays Performance from memory) that is pretty good at heads as well.
Kurrajong avenue, but the St Mary's side, not the Mt Druitt side.
KB
PostPosted: Mon Oct 13, 2014 4:23 pm
I was initially alarmed at that too, but it is just a polish mark.
All he bores are nice and smooth with no ridges at the top.
The "rust" on number 3 was only build up from the mud in water and came off with almost no effort.
PostPosted: Sun Oct 19, 2014 6:09 pm
Update
Installed the refurbed head (skimmed, recut valve seats and valves).
Drained and changed the oil and filter and refilled the radiator with coolant.
Started the engine and all seamed good.
Wen't for a short drive and the engine felt better than ever before.
Almost home and we could smell hot oil :?
Pulled up in the drive with engine running and fumes were coming out of the rocker cover breather.
Shut down and it ran on again.
Infrared temperature on head was 130c and radiator was 86c.
Let it cool down and the radiator was almost empty again. Topped it up.
Pulled the plugs out and did a compression test. Plugs were nice and clean.
#1, 120psi
#2, 120psi
#3, 110psi
#4, 120psi
Is it a cooling system issue (blocked radiator, dud thermostat, water pump).
Would a really hot engine cause the fuming as the compression is OK so no blowby from the rings.
Lost :roll:
PostPosted: Sun Oct 19, 2014 7:43 pm
Did you flush the cooling system? Replace thermostat?
Probably should have run straight water for the initial run in and make sure there was no air locks in the cooling system before the test drive.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Mon Oct 20, 2014 7:39 pm
Pulled the thermostat out and hung it in a pot of water.
Slowly heated to boiling point and the thermostat didn't open :(
Oh we'll, at least I now have the problem solved :D
What temperature thermostat should I buy ?
PostPosted: Mon Oct 20, 2014 9:46 pm
when you change head gaskets it is a good idea not to run with coolant for a while as it can cause leaks while the gasket is bedding in, thermostat temp cant help with
It's easy once you know how.
PostPosted: Tue Oct 21, 2014 12:06 pm
I use an 82C. I used to use a 74C, but then the heater worked like cr@p in winter.
An 88C is a bit hot IMO. OK for Pommyland...
PostPosted: Tue Oct 21, 2014 7:43 pm
Just tested the new thermostat.
Started opening at ~82 C and was fully open at ~86 C. As the water cooled it was fully closed at ~75 C.
Will test it in the car tomorrow night.
