It is currently Sun Jul 27, 2025 2:40 pm
 Post subject: mini related honest.....
PostPosted: Fri Oct 24, 2014 8:08 pm
New toy arrived today... gonna make life so much easier.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Fri Oct 24, 2014 8:14 pm
Great items to own!
PostPosted: Fri Oct 24, 2014 8:29 pm
You'll be amazed what aplications other than cars you can use it for.
PostPosted: Fri Oct 24, 2014 9:39 pm
Nice toy i meam tool that would come in very handy
PostPosted: Fri Oct 24, 2014 10:25 pm
show us more
PostPosted: Fri Oct 24, 2014 10:51 pm
What is it? And where did you steal it from? :lol:
PostPosted: Fri Oct 24, 2014 11:23 pm
Its a spot welder marty.....
Minis..
1975 van
PostPosted: Sat Oct 25, 2014 9:57 am
a real big one too!
PostPosted: Mon Oct 27, 2014 2:01 pm
First test run of the spot welder.
Hardest part is holding the damn thing. Its bloody heavy..
Minis..
1975 van
PostPosted: Mon Oct 27, 2014 2:17 pm
Pretty
PostPosted: Mon Oct 27, 2014 10:43 pm
you need to hang it in a bungee or pulleys to counter the weight, then all you need to do is manouvre it. that is how the factory did it, good enough for me.
PostPosted: Tue Oct 28, 2014 4:44 pm
I want one also. Would make life sooooo much easier replacing panels as well as making it more of a factory look finish. Nice
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue Oct 28, 2014 7:38 pm
how does it work exactly?
Is it as simple as "clamping" it over the 2 bits of metal you want to weld?
is it just a case of clamping it for the correct amount of time for the metal you are trying to weld?
1975 Hairy Lime/White Clubby
PostPosted: Tue Oct 28, 2014 7:50 pm
The tips are like electrodes I believe and when touching it completes the circuit and fuses the metal together (I think).
5/72 Clubman Gt
PostPosted: Fri Oct 31, 2014 10:24 am
Great bit of kit. Not as strong as a plug weld but a lot quicker. Have you chisel tested a join?
