It is currently Sat Jul 26, 2025 9:42 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Tue Nov 04, 2014 6:08 pm
My newly built 1340 motor continues to run for a few seconds after ignition cut off. I always thought this was caused by excessive carbon build-up in the combustion chambers or piston tops which when hot act like little glow plugs!
Any ideas?
PostPosted: Tue Nov 04, 2014 8:17 pm
too high compression for low grade of fuel, timing?
PostPosted: Tue Nov 04, 2014 8:20 pm
I'm using BP Ultimate 98 RON fuel and timing should be good, I'll look at compression in the morrow.
Cheers :D
PostPosted: Tue Nov 04, 2014 8:47 pm
What spark plugs are you running ??, I have the gear to cc a head if you need a hand.
I would re check timing and even advance a couple of degrees to see if it makes a difference.
My guess is that your carb mixture is to rich, what carb are you running.
Mal
PostPosted: Tue Nov 04, 2014 9:05 pm
Mal
Cheers Mal,
My plugs are NGK BP5ES and look a tad lean if anything (the tips are black and the ground electrodes are white)! The carbs are twin 1 1/4 SU's
I have a compression tester so I check that and post results tomorrow.
PostPosted: Tue Nov 04, 2014 9:23 pm
Not that kind of compression. Would involve removing head!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue Nov 04, 2014 9:29 pm
Oh bugger! Sorry, I'm still learning :oops:
Mal, the offer to give me a hand? Where abouts are you? When are you free?
PostPosted: Tue Nov 04, 2014 9:46 pm
Marty , I will send you a PM
PostPosted: Wed Nov 05, 2014 6:36 am
On a well modified 1275 running 98 it's pretty normal, IMO. With an iron head, anyway. If it doesn't do it, your C/R is too low. :)
I doubt it's the plugs, you could try colder ones but they are more likely to foul in traffic.
PostPosted: Wed Nov 05, 2014 6:57 am
drop your idle down a tad
&/or
retard your ignition a little bit
both of these will help reduce the chances of "run-on"
PostPosted: Wed Nov 05, 2014 8:21 am
How does retarding ignition help, there is no spark when you've turned it off!
It's either hot spots in the head, or red hot plugs...
Mine does it when hot, even though the head is bathtubbed and has no beak.
I just let the clutch up with the footbrake on, I've done it for years. :D
PostPosted: Wed Nov 05, 2014 8:31 am
I am guessing if timing is to far advanced you will not burn all the fuel in the chamber, hot spot or very high CR would ignite it once ignition is turned off ?
PostPosted: Wed Nov 05, 2014 9:08 am
If compression is too high is it possible to reduce it?
PostPosted: Wed Nov 05, 2014 9:29 am
More dish in your pistons, or get your head worked to increase the chamber size
PostPosted: Wed Nov 05, 2014 10:04 am
Marty, that will mean head off and possible engine strip, do you have any details of pistons and or head work ?
M
