It is currently Tue Jun 24, 2025 4:29 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Gearbox rebuild
PostPosted: Wed Nov 05, 2014 8:59 am
Manual says select 1st and 4th with 4 synchro boxes, 2nd & 4th with 3 synchro ones.
Don't select 2nd and 3rd together, the torque multiplication between them will rip teeth off, as my mate found with his Sprite box. :cry:
PostPosted: Wed Nov 05, 2014 5:54 pm
:oops: And don't use rattle guns :oops:
PostPosted: Thu Nov 06, 2014 11:41 am
The Bushes for the gear lever shaft in the back of diff housing can be replaced by a Dufor Bush DB155 available from any reputable bearing outlet.
"Let us remove your "SHORTS"
PostPosted: Thu Nov 06, 2014 11:51 am
Maybe. I've taken them off with a rattle gun before. If it's the first time the nuts have come off since the factory, they will be held on very hard. I had it upside down on the floor with my dad and brother standing on top, and it was still turning the box before the bolt would move.
PostPosted: Thu Nov 06, 2014 1:09 pm
I bolt a 2M length of conveyor side channel (150mm wide U section) to the top of mine and sit it on the ground. It ain't going anywhere.. :)
I used to wind the boat trailer's bum down onto it, but thats in Qld now so I made other arrangements.
My mate bolts his on top of the sturdy workbench, that works too.
PostPosted: Thu Nov 06, 2014 5:40 pm
I got it all apart, now I either need replacement gear parts or a complete replacement gear set. How do I tell what laygear I have if their is a difference?
PostPosted: Thu Nov 06, 2014 5:53 pm
There is a number on the laygear,
std gears use a 22G927, Cooper S and GT gears (with 18T 1st motion shaft) use a 22G1040.
If you need a 927 laygear you can have one for postage. :wink:
Good 2nd gears are hard to find, the engagement dogs get chewed up if/when the synchro goes.
PostPosted: Fri Nov 07, 2014 8:22 am
I ordered a used 2nd gear from Guessworks UK: http://www.guess-works.com/Shop/Parts/? ... %20Aseries
I think it was a bit cheaper when I got it, but still not the $100+ for a new one. They had re-surfaced the cone of the gear too, and it seemed to work well (didn't solve my 2nd gear cruchies, but I don't think the gear's to blame). If you can't find an equivalent Australian supplier, I would recommend Guessworks.
PostPosted: Tue Dec 09, 2014 4:44 pm
I'm doing a bit more work on this again.
What is the best way to remove the studs and locating pins from the housing :?:
PostPosted: Tue Dec 09, 2014 6:19 pm
The studs all screw out, either use 2 nuts locked together or a pair of vicegrips.
The dowels come out with multigrips if stuck in the housing. If tight, warm the case there with a hot air gun.
Then deburr the dowels by holding in a drill and using sandpaper, if necessary.
PostPosted: Tue Dec 09, 2014 6:21 pm
I never did - but if I were to try, I'd use vise-grips with something soft in the jaws (maybe gasket cork?) to avoid damaging them.
If you do take them out, it would be a good idea to re-tap the threads just to remove crud; after cleaning anything can get in there.
Edit - the doc beat me to it!
