It is currently Sat Jul 26, 2025 6:24 pm
PostPosted: Mon Sep 29, 2014 1:10 pm
hi,
Is anyone else finding the quality of the tie rod end ball joint rubber boots a bit lacking these days?
Once upon a time ago they used to out last or be on par with the useful life of rod end itself, but these
days seem to deteriorate with in a year or so. Is there anywhere you can buy just the boots? I've tried
a couple of mini store online catalogues but can't find them listed on their own. Does anyone now of a
place that sells them in OZ?
thanks
PostPosted: Mon Sep 29, 2014 1:22 pm
They are still listed by Karcraft.
p/no 17H3481/2
PostPosted: Mon Sep 29, 2014 4:23 pm
Thanks doc. :)
PostPosted: Tue Sep 30, 2014 11:43 pm
http://m.ebay.com.au/itm?itemId=280497984907
Found this. ..
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Wed Oct 01, 2014 2:24 pm
Online
At Karcraft they are $2.15 each..
PostPosted: Wed Oct 01, 2014 2:32 pm
Plus postage :)
PostPosted: Fri Nov 07, 2014 6:56 am
Yep I agree with ykg2s4's initial post.
My Tie rod ends are less than 2 years old, car has done <1000k's since then, and both boots completely perished. Purchased from a well known UK supplier. Will have to grab some boots from Karcraft.
PostPosted: Fri Nov 07, 2014 7:07 am
Just an idea I've used before, the dust boots off wheel cylinders fit and are usually good quality rubber type material.
