Hobson wrote:
As you know you have mine, I sent a few all in different light conditions, and over 2 different cameras, maybe each colour needs set/album. would mean alot of work, but say you had a drop box, or similar you could just do year, then base colour, like blue red yada yada then specific, like mine for example a folder on squadron blue
At the moment I am planning to go alphabetically by colour name to start with and build from there with metadata to assist with searching. At present there is 116 colours in the colour chart section for the Australian produced mini's upto 1978 from Acacia to Zircon White (not including the pre 64 850's) so just to complete that collection alone is going to need at least 116 photos, if I can get multiple photos for each colour I will most certainly be putting them in as the more we have the better the resource will be in the end.
As to how the end layout is determined, I think it will be redone a few times as I go because I am sure the best laid plan is not going to survive it's first contact (well at least someone said so once...) There are a ton of photos already in the forum that I could use from the various events where members have taken photos of hundreds of minis in single shots, the only catch is being able to verify what colour they actually are?
