Mick, they are a copper core, olde skool design and very reliable.
Their weakest point was the crappy alloy heater tap fitted just above the passenger's feet. They used to clog up with crud when not used.
IMO for reliability it's a good idea to bin it, and put a heater tap on the back of the cylinder head like the Cooper S had.
Yep Doc, but...the cores can also be full of engine crud, spiders or wasps nests, verdigris, old core cracks that were left because the fix was too expensive, hardened or split heater hoses etc etc...not to mention the heater tap weakness you mentioned...
Once again, if you are reactivating something that has not been used for 40 years...do some basic maintenance, new coolant and a pressure test...
Verdigris is the common name for a green pigment obtained through the application of acetic acid to copper plates or the natural patina formed when copper, brass or bronze is weathered and exposed to air or seawater over a period of time. It is usually a basic copper carbonate, but near the sea will be a basic copper chloride. If acetic acid is present at the time of weathering, it may consist of copper(II) acetate.
