It is currently Sat Jul 05, 2025 7:41 am
PostPosted: Tue Nov 18, 2014 5:32 pm
A mate of mine has a new Pearce Castings 7 port alloy head, however in order to avoid valve spring crush
with the cam he's using he needs to fit valves that are 100 thou longer in the stem. He says he cannot find anyone that can manufacture these in Australia or Britain.
Can anyone recommend a company that can produce these valves? They are not something weird just standard Cooper S valves that need to be a slightly longer.
I thought getting valves made to order was not that difficult to source, but he says that's not been his experience.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Tue Nov 18, 2014 5:55 pm
Oh dear, worry, worry...
HI Slide
I have the valves you want a little bit bigger in dia than the ones you have but they work really well in those heads give me a ring.
Graham Russell
PostPosted: Tue Nov 18, 2014 7:51 pm
Martini heads here in Melbourne will make any size/length valve you like.
http://www.martiniheads.com.au/index.html
Have a Nice Day.
PostPosted: Mon Dec 01, 2014 3:52 am
G&S Valves in the UK will make any type/size of valve you want. The problem will be the cost. I know GR has offered valves, but for the record I think Richard Longman here in the UK may be able to help out as he has longer stem valves to work with the roller spring platforms he giot in to fitting.
PostPosted: Mon Dec 01, 2014 9:07 am
What you need are different valve caps. Talk to MED they don't list them but if you ask nicely you might be lucky. I have a spare set here somewhere.
PostPosted: Mon Dec 01, 2014 12:51 pm
Slide, get 2 sets from MED and I'll take one set.
May as well make the postage worthwhile!
Please PM me with costs etc.
PostPosted: Thu Feb 26, 2015 3:16 am
Spring retainer combo + machine spring pad.
What is the current installed height?
What lift does he want to run?
Breaking heaps of stuff isn't the same as R&D since the "R" implies you actually did some research
G&H is the most applied practice by performance engine builders
G = Guess & H = Hope
