It is currently Tue Jul 29, 2025 4:01 pm
PostPosted: Fri Nov 21, 2014 9:26 am
You can Kinda see it in this pic, but how do you get to the top of the drives break hose on a 78 leyland. The passenger side has a handy cutout (that may not be standard not sure), but the drivers side looks as if the panel was pulled away to get in at some stage.... How are you mean to do it???
Nick
PostPosted: Fri Nov 21, 2014 9:57 am
You can get at it from above with sockets & difficulty, or..
You can bend the panel out for access then bend back when finished, or..
You can cut a slot in the inner guard like on the LH side.
My car is a bitsa, so I eventually (after 20 years) took the 3rd option. :wink:
PostPosted: Fri Nov 21, 2014 10:09 am
I got someone to hold the bottom and i undid the top with a few extentions on the socket my 74 had the brake light switch around there as well i remember pulling it out when i changed that hose
dont know if the 78 had the brake light switch in the same spot
PostPosted: Fri Nov 21, 2014 10:10 am
Thanks Doc.
Nick
PostPosted: Sat Nov 22, 2014 3:46 pm
Shitty shitty job!
PostPosted: Sat Nov 22, 2014 7:50 pm
Mick wrote:
Shitty shitty job!
Yep i can smell the shitty from here
I only bent that plate when i changed the upper arm bushes to get the nut off on that side
PostPosted: Sat Nov 22, 2014 8:15 pm
Almost as shitty as rear radiator surround bolts!
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sun Nov 23, 2014 8:32 am
Hey there's a trick here-
Slot the top half of the shroud to the bottom edge, where it fits over the middle rear screw. Then you can leave that screw in, just loosen it off and remove the top half.
Works for me...
PostPosted: Sun Nov 23, 2014 8:53 am
i did mine through the top, was pretty easy using a small handled 1/2". i drained my brakes first as i knew i couldn't do the drivers fast enough just gotta disassemble everything on that long bolt before it
PostPosted: Mon Nov 24, 2014 9:04 am
I used a brake union spanner and slotted that on the top, then got underneath. It's an awful job, I did notice that my panel was bent where somebody has bent it out before...
Users browsing this forum: lotsofminis and 91 guests
