It is currently Sat Aug 02, 2025 8:30 pm
PostPosted: Wed Nov 26, 2014 9:25 pm
So i have been doing a little research on the topic of increaseing the diameter of the Rover Mini SPI throttle body. I have concluded that it is possible and that its quite a comman modification in Japan, they uprated the standard 41mm throttle body to 45mm.
My question is has anyone here attempted it and if so was there a noticably diffrence in power ?
PostPosted: Wed Nov 26, 2014 10:22 pm
This is the first i've heard of a bigger throttle body on an spi (though i do have an spi manifold thats been ported out to flow better)......its done on mpi's cause its easy and serves a benefit but on the spi's the throttle body isn't the power restrictor.
Realistically, the most power you would get from that modification alone would be about 1 hp, if you've already got extractors and exhaust, ported head, sports air filter and raised compression, then maybe it could work.
PostPosted: Thu Nov 27, 2014 6:44 am
Specialised Components make an upgraded throttle body kit. It's one of the few places that do parts for spi engines
http://www.twinkam.co.uk/shop/article_S ... 218.001%26
PostPosted: Thu Nov 27, 2014 6:56 am
i offer this modification since years. not worth any HP if your engine is unter 85 - 90 HP. remember this TB was original fitted to Rover K series engines with up to 95HP before it found its way to the A series
Rover 214 atm ....
Users browsing this forum: minihahanz1 and 113 guests
