It is currently Wed Aug 06, 2025 12:13 pm
PostPosted: Thu Nov 27, 2014 8:09 am
Anybody know how to remove the cooper s 'whiskers' without damaging the paintwork? I need to replace the grille moustache. :?:
johnl
PostPosted: Thu Nov 27, 2014 8:13 am
If the brackets are riveted on can you drill them out from the back?
PostPosted: Thu Nov 27, 2014 3:30 pm
John
Go to your local SCA , Repco etc and get one of those plastic trim removal kits
has a few different types in them
or you could go to a barber and ask him to shave your whiskers :D :D
Mark
PostPosted: Thu Nov 27, 2014 3:47 pm
Thank you for the helpful and not so helpful replies.
I was hoping to not have to drill out the rivets, as I only need to remove them so I can replace the moustache which goes under the whiskers.
Hi Mark, did you end up selling your marvellous S ?
johnl
PostPosted: Thu Nov 27, 2014 5:37 pm
High heel ninja
Wrap some rag around a flat blade screw driver and pop them off, refit by giving them a tap with a rubber hammer.
Doogie
PostPosted: Fri Nov 28, 2014 3:15 pm
No John , I have not sold it and I am glad I didn't
I think I would regret it if I had
Mark
PostPosted: Fri Nov 28, 2014 4:46 pm
Put some masking tape around the whisker first to protect the paint, then with a thin small paint scraper slide this under the edge of the whisker so you have something to lever against rather than your paint. if you now take your time with a similar thin bladed screwdriver or another paint scraper you will pop it enough to do your task.
Users browsing this forum: Gambo and 85 guests
