It is currently Tue Jul 22, 2025 7:45 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Dec 02, 2014 8:48 pm
Brad, is there a spacer under the clutch master cylinder? If so remove it, will help with the clutch taking up just off the floor, particularly with the .7" master bore.
Steve
PostPosted: Tue Dec 02, 2014 9:08 pm
Hey Steve. No only the bracket that sits on the bulkhead under both MCs, which is part of the engine steady bar.
I did notice the new slave cyl pushrod is actually a few mm shorter then the original one which wouldn't of helped much!!!
See how I feels with the new clutch arm anyways.
