It is currently Tue Jul 22, 2025 7:10 am
 Post subject: Quick diff question.
PostPosted: Tue Dec 02, 2014 3:46 pm
Sounding like a newbie, what's the pro's and con's of both 3.4 and 3.7 crown-wheels??
If it has tit's or tires....It'll take all your money!
74 Leyland Clubman S (scrap)
77 Leyland Clubman S
 Post subject: Re: Quick diff question.
PostPosted: Tue Dec 02, 2014 5:59 pm
3.44 is good for a road car, as long as the motor is a 1098 or bigger.
3.76 was fitted stock on 850, 997/998 Cooper and 998 Mini Deluxe, is also used in group Nb race cars. It's a bit busy for cruising with a big motor.
In between there is a 3.647, was fitted to most Mini K and 1100 Clubbies using the remote box.
PostPosted: Tue Dec 02, 2014 6:36 pm
So a 3.76 (22g401) is best for a standard 998?
If so it looks like I have a 22g411 to sell.
PostPosted: Tue Dec 02, 2014 7:30 pm
Basically the higher the number the more revs you'll be doing at 100km/h. Or to put it another way the faster you'll accelerate off the line.
PostPosted: Tue Dec 02, 2014 8:14 pm
3.44 was used in most Mini rodchange boxes, including the 998 from 1975 on.
A 3.76 is better for going up hills with a 998 though. :wink:
PostPosted: Wed Dec 03, 2014 6:36 am
Thanks guys.
PostPosted: Wed Dec 03, 2014 8:58 am
Like Doc says... but consider carefully what you intend to do ... and where you live.
A 3.7 will blunt the acceleration edge and require an earlier downshift on hills.
The upside is a much more relaxed car if you spend any amount of time on the freeway/highway..
Cheers, Ian
Oh, and BTW, its not just the crown wheel involved in ratio change..
PostPosted: Wed Dec 03, 2014 10:05 am
Cheers, Ian
Ian you got that statement arse about... :)
PostPosted: Wed Dec 03, 2014 10:46 am
Why? just tickle the engine a little so that it will pull the higher diff and enjoy the lower revs when cruising...(if that is your thing and the type of work the car does).
PostPosted: Wed Dec 03, 2014 11:37 am
Cheers, Ian
Not a big problem ...only the numbers are wrong.... and I got the three correct :oops:
But just to remove confusion.. I should have typed "3.44"
Cheers...
PostPosted: Wed Dec 03, 2014 2:43 pm
Ok so snap question, what is the best diff ratio for a stage one 998 to be used for shows and general Sunday cruising???
PostPosted: Wed Dec 03, 2014 2:59 pm
3.44 then. :)
PostPosted: Wed Dec 03, 2014 6:05 pm
Thanks drmini.
Users browsing this forum: Bing [Bot] and 96 guests
