It is currently Wed Jun 25, 2025 6:11 pm
 Post subject: mini K bonnet badge
PostPosted: Fri Dec 05, 2014 11:40 am
Hi All,
Does anybody have a good photo of an original Mini K bonnet badge that shows what the original colouring would have been. I am going to re cast my old one and wish to reproduce it to original. Any help would be appreciated.
Ian
 Post subject: Re: mini K bonnet badge
PostPosted: Fri Dec 05, 2014 4:04 pm
I have made my own K badges from the original badge that was on the car when new. The moulds are in silicon casting rubber. The first batch, years ago, came out OK, but recently I've had trouble with the casting resin finish and trying to keep air bubbles out of the mould.
Colours are Humbrol/Airfix type modelling paint:
the ox is bright red, the 3 waves below the ox are mid-blue.
The whole background is light-grey metallic, where I used a small spray can of modelling paint to get an even effect.
PostPosted: Fri Dec 05, 2014 4:18 pm
Here is a couple of photos of a new old stock Morris 1100 bonnet badge to give an idea of the colours...
PostPosted: Fri Dec 05, 2014 8:35 pm
Wonder what the bull ment most likely just a symbol like the gmh lion
PostPosted: Fri Dec 05, 2014 9:23 pm
the bull is an ox the three wavy blue lines mean a ford in a river so the badge means OXFORD
65 panel van Sprog
73 panel van Iggy
PostPosted: Fri Dec 05, 2014 9:53 pm
William Morris (later Lord Nuffield) started business in the city of Oxford.
Like frednutz&co said an ox crossing a river = Oxford.
So the Morris symbol probably has more meaning than the Holden lion.
BMW still builds Minis in Oxford.
PostPosted: Sat Dec 06, 2014 11:17 am
Ok a new thing learned today
PostPosted: Sat Dec 06, 2014 11:38 am
Thanks for the replies. I have a vac chamber and do a bit of casting for my model railway business so should not be too much trouble getting a perfect reproduction.
Any other pics out there would be of help also.
Ian
PostPosted: Sat Dec 06, 2014 12:58 pm
iansmini67 wrote:
... should not be too much trouble getting a perfect reproduction.
I reckon there's a few people who would love a good quality reproduction of this badge since originals are so scarce (and expensive). Could be a little money earner on the side for you if you decide to go into production.
PostPosted: Sat Dec 06, 2014 1:13 pm
Yep I would definitely be keen to purchase if you made them.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sat Dec 06, 2014 4:26 pm
I will keep this thread going with updates on the progress and If there are no issues I will make a few and see what happens. I plan do make up the rubber and do the casting over the xmas break.
Ian
PostPosted: Sat Dec 06, 2014 5:42 pm
The hardest part will be the silver parts. I believe this to be vacuum metal deposition. While I would like to be able to replicate these badge, this is something I would have to outsource. The vacuum required for metal deposition (usually aluminium in this case) is very high, something like an oil diffusion pump backed by a good quality rotary vane pump is needed.
I'm refurbishing a welch 1373 to try my hand at casting these, I tried polyester resin but it is unsuitable. You will need a water clear urethane.
PostPosted: Sat Dec 06, 2014 5:43 pm
As a side note these badges were also featured on the MK2 Minimatics in the UK. You may be able to source a good badge from there.
PostPosted: Sat Dec 06, 2014 5:48 pm
That almost looks like a gold colour, In the circle and crest thing.? or is it the light?
PostPosted: Sun Dec 07, 2014 7:58 am
There is a gold leaf that is called "Moon gold" that is exactly that light shade. I reckon there is a real good chance that would be it.
Users browsing this forum: Bing [Bot] and 105 guests
