It is currently Tue Jun 24, 2025 2:57 am
PostPosted: Sun Dec 07, 2014 1:58 pm
Does anyone have a suggestion on a breather and better yet one available that gets me around this?
Regards
Dave
1993 R32 Nissan Skyline GTR
PostPosted: Sun Dec 07, 2014 2:39 pm
A later model breather of a verto cluch would works. Minisport sell them. http://minisport.com.au/mini-clutch-hou ... all-models
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Dec 07, 2014 3:10 pm
Or simply cut a section out of the base pipe to change the angle and braze it back together
PostPosted: Sun Dec 07, 2014 3:36 pm
Or one of these
http://www.dsnclassics.co.uk/mini-parts ... let-alloy/
1963 Morris 850
PostPosted: Sun Dec 07, 2014 5:02 pm
Getting rid of that adjustable pedal box should solve the problem you're having. :P
PostPosted: Mon Dec 08, 2014 6:47 pm
PostPosted: Mon Dec 08, 2014 6:51 pm
Thanks to all for there advice
PostPosted: Mon Dec 08, 2014 10:44 pm
Dave, I made up a alloy breather pipe , packed some steel wool from the kitchen into hole to help stop oil vapour, has been working fine for last three years.
Mal :-)
PostPosted: Tue Dec 09, 2014 3:09 am
Nice one mal, how do you find the dual master setup?
PostPosted: Tue Dec 09, 2014 6:38 am
I did away with that flywheel housing breather, as it gets lots of oil chucked up it on long LH bends at high rpm.
I ran a nylon line to the rocker cover to equalise the top to bottom crankcase pressure, it now pulls the fumes from the rocker cover to a Toyota PCV valve on the manifold. Working great.
[edit] typo
Last edited by drmini in aust on Tue Dec 09, 2014 12:09 pm, edited 1 time in total.
PostPosted: Tue Dec 09, 2014 7:17 am
Dave, the dual master are great, gives you good pedal every time.Make sure you put some socks over the reservoir caps , they leak through breather holes and make a mess under hard cornering.
The only downside is they need to be removed if you are doing an engine change, just make sure you make allowance when plumbing them up, in hind sight I would have fitted some custom braided hoses.
Mal
Users browsing this forum: Bing [Bot] and 99 guests
