It is currently Sun Jul 27, 2025 7:49 am
Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: meeni wants to stall
PostPosted: Thu May 19, 2005 5:44 pm
well i just gave the car a run up the driveway and back and found that no matter how hard i pushed the throttle to get the revs up, the car wanted to stall, i dont understand why, although my throttle cable may be playing up??? can anyone help me out here?
Potato
PostPosted: Thu May 19, 2005 5:55 pm
I had this issue with my Deluxe......was me being tired and putting the leads on the wrong plugs.
Did the same thing to the Suzuki Swift also.
PostPosted: Thu May 19, 2005 5:58 pm
Could be running rich and the more you put your foot down the more fuel it gets...
You could check the timing, plugs, point, leads etc
Roads need more corners
PostPosted: Thu May 19, 2005 6:01 pm
Err its not warmed up enough.
mine does this when its not warm enough... lets me know i'm not allowed to go anywhere till shes warm enough :)
PostPosted: Thu May 19, 2005 6:34 pm
nah mine had been running for half an hour prior to get the battery charged, it maye have been throttle as i just came in from adjusting that and it seems to be revving higher with less push of the pedal, it is running rich also, thanks guys :wink:
Potato
PostPosted: Thu May 19, 2005 6:49 pm
Plugs fouled?
Idling for 30 mins shouldnt do that tho..
Meh i dunno.. you've got a few YEARS to sort it out, anyway :wink:
PostPosted: Thu May 19, 2005 6:59 pm
:cry: dont rub it in, well i may be on the race track soon so that will slightly help my wants/ needs
Potato
PostPosted: Thu May 19, 2005 8:15 pm
Not enough petrol in the tank?
PostPosted: Thu May 19, 2005 8:18 pm
nah theres plenty of petrol, its mainly cos its runnign rich i think, i will give it a shot in the morning to see if adjusting the throttle did anything. :wink:
Potato
PostPosted: Thu May 19, 2005 8:21 pm
you posted ages ago that it was sluggish - you're always taking it shows on a trailer, why don't you put it on that trailer and go get it tuned properly, maybe at that mini place where you work and learn all your skillz....
sounds like it's retarded to me, but it could just as easily be a dragging rear brake, or maybe it's because the interior light isn't working....
PostPosted: Thu May 19, 2005 8:24 pm
I had a Commonwhore just like this many moons ago.
It had a 253 that I bought from a wreck. Supposedly it had done 125 000 kms......but after much deliberation I figured that it must have been flogged real hard before the car was wrecked.
I lived on a hill and would have to leave for work at 5am and drive up the hill....the car would just not do it, so I had to go down the hill and get a run up, just to make it up....
I reckon this motor had low compression (from wear)....
How is your compression??
PostPosted: Thu May 19, 2005 8:27 pm
Yea. could be.
Checked if it could be busted head gasket?
Fricked crankshaft?
Hmm whats some more things that would freak him out?
Oh... cracked head?
PostPosted: Thu May 19, 2005 8:30 pm
erm, don't idle your car for 30 mins from cold...
you need to drive it to get oil pressure up and oil temp up to operating norms as quickly as possible.
the other day mine wouldnt get up our drivway no matter how much i tried it turned out to be a dead plug cause it was a little rich
PostPosted: Thu May 19, 2005 8:51 pm
yea, could be electrical.....do you have a new loom, or is it 43 years old? Could be something up in the loom somewhere....poor or weak spark.... :?
Users browsing this forum: justminis and 112 guests
