It is currently Wed Jul 23, 2025 12:11 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Thu Dec 11, 2014 10:52 am
guys my mini Van is ready to go to the shop, I'm having trouble identifying what it is for the guys at the motor reg dept.
I bought her as a rolling shell and need to try and find her previous plate number or chassis number, there are no tags and the only identifier I can find is the 18## stamped on the radiator shroud.
At some stage she has had the rear corners and front plate holder " customised". There was a "brickworks racing" sticker on the front window who i believe was a shop / club here in SA ?
Any one able to help me try and find out what model she is and what her chassis number is - i may then be able to find her plate number..
Or even better if a previous owner is on here??
David
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Thu Dec 11, 2014 11:25 am
Mini K van.
PostPosted: Thu Dec 11, 2014 11:45 am
Thanks DrMini
So would that make her chassis / body number YJBAV4 18##?
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Thu Dec 11, 2014 1:11 pm
Sorry, I'm not up on van body prefix, but yes the Mini King book says it is so.
It may be wrong though... most lists in non-factory books and on other Oz websites have errors. :lol:
[waits for morris 1100 or winabbey to log in...] 8)
PostPosted: Thu Dec 11, 2014 1:51 pm
Thanks - Will see what the others have to say... I'm praying someone say oh thats my old car and can tell me the old rego plate number....
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Thu Dec 11, 2014 2:17 pm
That would be my guess. Other than Morris 1100, John Sneddon is a resident expert on car identification. He's compiling a database of the body prefixes, engine prefixes and relative numbers for Australian Minis so he could give an approximate delivery date for a body with 18xx.
Are there any holes in the front of the front subframe suspension tower? This is where the ADR compliance plate would've been fitted if it is a January 1970 or later vehicle. Initially there were four holes (one in each corner of the plate) and then two when a smaller plate was used.
PostPosted: Thu Dec 11, 2014 2:25 pm
nothing there as you describe, there is however 4 little holes under the wiper panel on fire wall on the drivers side where it looks a plate might have been at one stage?? I checked with motor reg here in SA and they tell me its likely it never had a plate but may have had one fitted at a later date when an engine change was done ( i doubt this though as if it had had an upgrade from 1100 to 1275 requiring an inspection i thought it would have had disk brakes? )
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Thu Dec 11, 2014 2:29 pm
Then it may be a 1969 delivery date. There were no ID or ADR compliance plates until January 1970.
PostPosted: Thu Dec 11, 2014 2:32 pm
This thread may be of interest - viewtopic.php?f=2&t=50764
PostPosted: Thu Dec 11, 2014 2:56 pm
ok so I'm going with a 69 Mini K Van. unless anyone can prove otherwise..
now just need to find the old owner to find out the number plate details...
Thanks everyone
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Thu Dec 11, 2014 3:04 pm
OK so SA motor registration department has no records with the chassis/body number. They need either the original engine number or the old number plate details, back to square one...
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Thu Dec 11, 2014 6:27 pm
Vans and Mokes still had plates. Commercial Vehicles had to have a plate with a GVW.
Vans build before and after this one had plates.
There should be 4 rivet holes behind the master cylinders.
PostPosted: Fri Dec 12, 2014 7:30 am
Is there any letters/numbers stamped in the radiator shroud?
If it is a late 69 model van during the period of no build plate this will be the only point of identification.
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Fri Dec 12, 2014 8:31 am
Hi John
Yes 4 numbers 18**
David
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Fri Dec 12, 2014 11:38 am
Hiya,
I had a van that had the numbers stamped in the bonnet channel on the passenger side. Maybe check there too?
cheers! jon
MX5 NA Clubman (1993)
MX5 NB SE Turbo (2004)
MX5 NB8B (2001)
RS Focus (2016)
