It is currently Mon Aug 18, 2025 6:25 am
 Post subject: Temp gauge doofus
PostPosted: Sun Dec 14, 2014 12:40 pm
Well I needed to get my speedo re-calibrated due to a new diff. That all went well until I re-installed everything and now the temp gauge hits the max in no time, i.e. about 3-4 minutes. Have I screwed the wiring up?
Gotta get this fixed as I hate pulling that console out :evil:
 Post subject: Re: Temp gauge doofus
PostPosted: Sun Dec 14, 2014 1:23 pm
Is the fuel gauge reading really high too?
PostPosted: Sun Dec 14, 2014 2:36 pm
Yes, it sounds like you have mixed your wiring up on the voltage stabiliser.
PostPosted: Sun Dec 14, 2014 2:45 pm
Mmm, thanks guys. I did check that and the fuel gauge is fine.
Green with blue tracer to the sender and green to the reg. Left and right respectively sides looking at the front of the dial.
I know that the engine is not running hot so it is a gauge issue.
Any other clues?
PostPosted: Sun Dec 14, 2014 2:56 pm
Any other clues?
The only thing I can think of is when you plugged your green wire into your voltage reg that you may of plugged it into the B terminal not the I terminal. I terminal is the correct 10volt you need for your temp/fuel gauges, and the B terminal is 12volt for your wiper motor.
PostPosted: Sun Dec 14, 2014 3:04 pm
Any other clues?
Now that sounds like something I would do :-/
Methinx that you are onto something. I will give that a go tomorrow as I can't be buggered taking the thing apart again today...I reckon it's nearly Miller time.
PostPosted: Sun Dec 14, 2014 3:21 pm
Anyone got a pic that shows which wire goes where on the back of the reg?
PostPosted: Sun Dec 14, 2014 3:36 pm
http://www.minimania.com/Smiths_Voltage_Stabilizers
this link may help you. Your temp gauge needs to be connected to the 'I' terminal
PostPosted: Mon Dec 15, 2014 7:48 am
Thanks mate; much appreciated.
PostPosted: Mon Dec 15, 2014 12:11 pm
All fixed.
Am glad that's over....pulling that binnacle in and out 4 times was doing my head in.
Thanks heaps for that link to the pic and thanks all for your generous advice...it always impresses me how helpful and knowledgable the ausmini folks are.
cheers, bam.
PostPosted: Mon Dec 15, 2014 5:09 pm
bamnfi wrote:
All fixed.
cheers, bam.
Glad it is all fixed - The wiring behind the binnacle can be such a pain to get right.
Users browsing this forum: No registered users and 210 guests
