It is currently Sun Jun 29, 2025 4:50 am
Post new topic Reply to topic  [ 538 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 36  Next
PostPosted: Sun Dec 14, 2014 6:45 am
Try covering the spare holes for the different motor positions.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sun Dec 14, 2014 8:25 am
it's nothing to do with those holes
PostPosted: Sun Dec 14, 2014 9:15 pm
Yeah really should have been a rubber seal there or something...
Why Drink And Drive When You Can Smoke Dope And Fly!?
PostPosted: Mon Dec 15, 2014 12:20 pm
I've never had an issue. Interesting. I've always used silicon spray in the gearbox. Are you using a lube of any sort?
PostPosted: Mon Dec 15, 2014 12:46 pm
yes, I've lubed the gearbox, but again, not the issue
stealing someone else's photos, here's the offending bit and where you're meant to grease it
the motor mount plate has an extra hole on it (1 o'clock on the top pic) that isn't used, and I think they've cut the edge of the right-hand side of the chassis to fit around it, but it's opened up a massive hole for stuff to fall down (1 o'clock on bottom pic) . Basically it comes in through that gap, sits on top of the curved bit where the motor mount lines up and then falls in.... I've filled mine up with silicone on both halves, it still comes apart, but it seals when I put it together
PostPosted: Mon Dec 15, 2014 12:53 pm
Maybe it's a V2 issue. There are a couple small little things that seem like it was rushed a little...
PostPosted: Mon Dec 15, 2014 1:05 pm
thats what it looks like...
PostPosted: Mon Dec 15, 2014 1:07 pm
Having said that, I'm never off the racing line. The racing line is always clean.
Which is all lies, well the first part anyway.
PostPosted: Mon Dec 15, 2014 2:03 pm
pfft, I even had bits of grass in my gearbox...
my car does a funny thing, one of the experienced guys noticed it too - the car runs straight when cruising but jumps to the left on sudden acceleration. Any idea what might make it do that?
PostPosted: Mon Dec 15, 2014 2:04 pm
I doubt your diff is too tight. Try a tad more tow out at the front.
PostPosted: Mon Dec 15, 2014 2:36 pm
gotcha... something like 1/2 a turn on one of the tie rod ends?
I don't like how much slop there is in the front (and rear) uprights, the outer CV moves in and out about 1mm - do we ever put little shims behind the hex flange pin or the CV?
PostPosted: Mon Dec 15, 2014 2:46 pm
Yes, I shim the movement out. If you buy the assembly uni joints they will come with the shims.
With an M05, I put spacers in the steering arms. Probably only needs .5mm taken out.
PostPosted: Tue Dec 16, 2014 2:40 pm
Yeah I shim mine too.
More for my own pleasure than because of the performance improvement!
I think it's the placebo effect! :)
PostPosted: Tue Dec 16, 2014 3:18 pm
can I see a spacer in the steering arm there?
just a little ring and you screw the rod ends up tight on it, yeah?
am I allowed to ask what size spacers??
PostPosted: Tue Dec 16, 2014 3:39 pm
Yep, they are silver in that photo. I have a tiny spacer in there at the moment. Probably .5mm. It's as much tow out as I've ever ran, but the diff is pretty tight, probably too tight. I use the Tamiya aluminium spacer kits, but you'll find you have some random spacers attached to a plastic parts frame.
