It is currently Wed Aug 20, 2025 12:03 am
 Post subject: Dizzy 25D and 45D
PostPosted: Mon Dec 15, 2014 9:01 pm
Question are a 25D and 45D dizzy interchangable?
 Post subject: Re: Dizzy 25D and 45D
PostPosted: Mon Dec 15, 2014 9:05 pm
Physically they are. The advance curve however may be very different.
PostPosted: Tue Dec 16, 2014 6:37 am
25D had a symmetrical cam, it was prone to `points bounce' over 6500 rpm. Except for the Cooper S which got 32oz points.
A 45D's cam is assymetric, so doesn't have this problem.
These days in the 21st century I'd fling the points & condenser from either, and fit an electronic module instead.
eg Powerspark, or Pertronix.
as for the advance curve, lock the dizzy's advance and add an Acuspark stealth module, and you can then programme whatever curve you need. Works for me.... 8)
PostPosted: Tue Dec 16, 2014 7:03 am
I sell both these Distributors 25D4 and 45D4 brand new and they are Electronic. You even get a choice of side entry or top entry caps with both types. Price is $150.00 post free. Buy Local and support local businesses who try and keep Mini parts available at a reasonable cost.
"Let us remove your "SHORTS"
PostPosted: Wed Dec 17, 2014 10:35 am
Thanks for the feedback, I plan on going electronic, if I was to go new dizzy would I be better to fit a 45D or going electronic it doesn't really matter?
I just saw the 45D is the for sale section of the forum and thought it's an upgrade I plan on doing.
And Convertible mini, I agree I try to buy local where possible, it might cost a couple of extra dollars, but it always seems to be less hassle from my experience.
PostPosted: Wed Dec 17, 2014 10:56 am
A new 45D with electronic module will work the same as an old 45D with electronic module.
But the advance mechanism of the new one won't be worn.
re the new one for sale by junior, we decided to use his old one instead, because he is also fitting an Accuspark stealth module for programmable advance. The dizzy's centrifugal advance will be locked so won't work anyway. :wink:
[edit] for clarity
Last edited by drmini in aust on Wed Dec 17, 2014 2:24 pm, edited 1 time in total.
PostPosted: Wed Dec 17, 2014 1:38 pm
Ah cool how much of a power gain can you get from using the programmable advance?
Also is there presets available or is it a bit of trail and error?
PostPosted: Wed Dec 17, 2014 1:51 pm
Here is the thread on it:
viewtopic.php?f=2&t=83483
PostPosted: Wed Dec 17, 2014 2:58 pm
awesome thanks, I'll have to have a read
