It is currently Sun Aug 10, 2025 11:15 am
PostPosted: Mon Dec 29, 2014 4:35 pm
Hi all
just wondering if anyone on here is using a wideband AF meter in their mini with a single SU.
I have had limited experience with it but it has been quite an insight into the actual tune of my engine. Ive been able to set my idle mixtures to exactly 14.7 to 1.
Im just curious how rich is too rich? under hard acceleration it richen up all the way to about 10 - 1.
it begins to lean up again as the engine load is lowered.
on over run and cruising speeds it may creep up to 16-1. this is not really an issue as the engine is making very little power at this point.
I am running a needle that most charts sites etc etc have recommended for my engine with the mods i have done. I think its an aau.. (1 1/2 su)
I would be inclined to think the needle should be slightly under fueling as the engine and head have been worked quite a bit.
just curious what readings you guys have seen?
blokeinamoke wrote:
PostPosted: Mon Dec 29, 2014 4:44 pm
im currently running an aau needle
blokeinamoke wrote:
PostPosted: Mon Dec 29, 2014 4:54 pm
10:1 is way too rich.
An SU should run around 13.0 under load.
Cruising at light throttle, 15.0 or a bit more is fine.
PostPosted: Mon Dec 29, 2014 7:30 pm
Unless you are running a Supercharger..... :roll:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Dec 29, 2014 9:49 pm
Yeah, or a turbo. He's not, so I didn't confuse him. :)
PostPosted: Tue Dec 30, 2014 4:14 pm
can any one tell us if the Minty Lamb needle chart can be used to plot a graph and then have it suggest the appropriate needle?
It's easy once you know how.
PostPosted: Tue Dec 30, 2014 5:24 pm
Sounds like you need a lighter oil in the dashpot if it is only going that rich on initial acceleration. I've used a wideband with my 1.5 SU and I was aiming for 14.5 idle, 12.5 full load, and about 16 or 17 cruise. I've used Minty Lamb and it works ok, just choose needles that are common more correct (rich or lean), in the areas needed.
PostPosted: Tue Dec 30, 2014 5:39 pm
Sorry to hijack.
What af would you recomend for a 8v fuel injected twinky?
Load is as low as 9:1 and 10:1
light throttle is 10-13.6
idle is unknown at this stage.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Tue Dec 30, 2014 5:58 pm
danny_ wrote:
Sorry to hijack.
I reckon 12s under full load,
15-16 light throttle cruise,
14-15 idle.
As you DON'T have a huffer or a turbo. :lol:
PostPosted: Tue Dec 30, 2014 6:06 pm
danny_ wrote:
Sorry to hijack.
14-15 idle.
I will adjust again.
The pipe you made up is working great.. It's been on the car all week and still going strong.
cheers.
PostPosted: Tue Dec 30, 2014 6:15 pm
The tailpipe sniffer doesn't allow idle readings because of the in-out airflow at idle. That dilutes the exhaust so it reads max lean.
If you want to get an accurate idle reading, weld the spare sensor nut onto the bottom of the headers and plug the sensor in there. When you're done with testing, screw an M18x1.5 plug into it.
PostPosted: Tue Dec 30, 2014 6:19 pm
The exhaust set up had a bung with no thread (capped with some metal rod) .. It popped off on the m5 and i had to weld a nut onto it about a month ago.
I might go to my local exhaust shop and see if they sell the correct size bung.
PostPosted: Tue Dec 30, 2014 7:14 pm
As a side.. I have been looking at these for a while...
What brand/model of wide band A/F meter are you using? And would you recommend?
Doc.Martin
PostPosted: Tue Dec 30, 2014 7:45 pm
http://www.streetfx.com.au/product/inno ... part-3844/
PostPosted: Tue Dec 30, 2014 7:58 pm
I have the same. I put it in a box and made it portable.
Sensor supplied is a Bosch.
Users browsing this forum: Bing [Bot] and 101 guests
